Old 09-14-2009, 03:17 PM   #11
Soylentglass
Drives: 2009 Yaris Sedan
I posted yesterday the results of my install on my 09 manual sedan and at first I ran into the same problem with the repair terminal not fitting. I ripped the waterproofing sleeve trying to jam it in with fine needle nose pliers.
My post is at the end of http://www.yarisworld.com/forums/sho...=16188&page=30
On connector A21 there is a locking mechanism that you must push to one side to allow the terminal to slide in place and yes it would only go in one way, which happened to be the 4th position I tried. You then push back the white plastic slide piece and it will lock the terminal in place.
Soylentglass is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
