Old 10-19-2009, 11:47 AM   #10
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I would totally go with CTScott's method with the Indicator Module. It's cheap and looks just as good as the Kits, or OEM installation. As long as you place the LED where you want it. I actually put mine in the Gauge Cluster to make it look more OEM, but I think it looks better than OEM myself. I'm sure if you take the time and have the skill you could scratch the OEM icon on the black cluster cover and it would look totally OEM.
The module does exactly what it says in the "CAN WE DO THIS" thread post #398. The light comes on for 1 second on power up and then works like a charm when in use. I equipped it with a white "12V ready" LED, but you can use whatever color you want.
I've noticed only one thing with your Module CTScott. When I hit the on/off switch two times really fast the CC reads two pushes, but the Module only reads one and actually inverts the LED. So you have to hit it again twice really fast to reset it. Also when I turn on my HID headlights there is a quick power drain that resets the module (the light comes on for a second and then the LED is reversed again because the drain doesn't reset the CC) But this only happens if I turn my CC on before the headlights. So if I hit the lights first I have no problems.
It's totally invisible until you hit the switch...see that little white dot?
Video of it working...
http://s236.photobucket.com/albums/f...t=CIMG7073.flv
My Car Rules!
nickhjort is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
