Old 01-22-2010, 06:25 AM   #91
Originally Posted by cynsofdm View Post
Wow this is awesome. It sounds easy enough that I could do it knowing nothing about cars or electronics. I was searching for this though because I am moving to Gainesville, fl from Atlanta, Ga tomorrow. I had to make the trip a couple days ago and my leg and back were killing me. I was hoping to find a way I could pull something off in a couple of hours. You think it's possible? I have a couple of guys familiar with cars and electrical stuff that are coming to help me move tomorrow...
The other thing was I really liked the "test" install Yaris07hb did, because then I could worry about mounting it later. Or possibly something even simpler... installing it in a slip of cardboard... I have tons of cardboard.
Also is the only worry with modifying the remote possibility of voiding a warranty? I bought my '08 HB used, and I don't have a warranty, at least that I know of... it's my first nice new to me car.
It can be done in a few minutes with the right tools. In the "Can we do this" thread that started this whole idea, I test wired it to two stand-alone switches as a quick test before drilling holes in the dash.
Old 01-27-2010, 05:30 PM   #92
frankencar
Drives: 2010 Yaris S
So this may be a silly question but... this works on an AT liftback as well? Just ignore the parts that say "MT only?"
Also, I'm a bit confused on the part where you connect to the ECU. Is there a specific crimp/connector, some other method to plug into the ECU?
frankencar is offline   Reply With Quote
Old 01-27-2010, 09:26 PM   #93
Correct on the AT - Works the same and ignore the clutch switch part.
For the ECM connection (on 06-08 Yaris), you need to actually add a pin to the smaller of the two connectors on the ECM. I highly recommend using the actual Toyota "repair terminal", which is the pin with its waterproof sleeve and a piece of wire pre-connected to it. (Part number: 82998-24250)
Old 01-28-2010, 04:36 PM   #94
wyolincoln
wyolincoln's Avatar
I performed this mod several months ago on my wife's 2007, 3 door liftback and decided to use the two switch method. Mounted two black switches on the small removable panel to the right of the column, just below the driver's side glove box. One switch provides on/off and the other switch provides the set function.
This mod has been working great and makes the car very pleasant to drive on all but the shortest trips. Plus one can't help but smile when knowing you have built your own cruise control for less than $10.
Thanks to all who posted schematics, pics, and ideas.
"Mistakes will be made.
Others will be blamed."
Paul Perves
wyolincoln is offline   Reply With Quote
Old 01-28-2010, 05:20 PM   #95
upgradedyaris
Drives: Yaris & Supra
You forgot to add your module for the led. ;) A plus!
Duane
upgradedyaris is offline   Reply With Quote
Old 01-28-2010, 11:24 PM   #96
myt
myt's Avatar
Drives: Blazing Blue 07 YAris
Ok so of course I HAVE to do this!! I have a M/T, does the brake disengage the Cruise Control or do I have to depress the clutch?
Thanks,
MYT
myt is offline   Reply With Quote
Old 01-28-2010, 11:52 PM   #97
Thanks,
MYT
Either will disengage it provided that you install the clutch switch, rather than bypassing it.
Old 01-29-2010, 01:39 PM   #98
rtom
Drives: 2010 Yaris 3-door liftback MT
Hey CTScott,
Is there a "sticky" or FAQ summarizing which mod procedure one should follow for different years/models of Yaris? I went through the long thread a month or two ago and I remember thinking that it would be better to add my own 2-way switch, but lately it seems everyone is talking about adding the stalk.
I ask this partly on your behalf -- if there's a sticky or FAQ up front in these CC threads, then surely you'll get fewer questions.
rtom is offline   Reply With Quote
Old 01-29-2010, 01:46 PM   #99
Originally Posted by rtom View Post
Hey CTScott,
That's a good point. There are sooooo many different threads (with bizillions of posts) all discussing with the same questions popping up, as it is pretty hard to find the answers without wading through. I think I will put one together...
Old 01-29-2010, 02:10 PM   #100
Here's a start:
Old 01-29-2010, 04:17 PM   #101
rtom
Thanks! That's a pretty efficient start.
I'm a good guinea pig because I'm planning to do this (well, when the weather warms up -- I don't have a garage). From my point of view, the next steps are to nail down (1) part numbers and sources, and (2) procedures and tools required. Probably it's not so hard to summarize part numbers & sources, but summarizing procedures might be trickier?
Anyway, thanks, and I'll start reading the threads.
Old 01-30-2010, 03:31 PM   #102
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Should we be disconnecting the battery when playing with the ECU?
Old 01-30-2010, 03:57 PM   #103
Originally Posted by Sodium Duck View Post
Should we be disconnecting the battery when you play with the ECU?
It would be a good idea to do so.
Old 01-30-2010, 08:55 PM   #104
Sodium Duck
╚══════════RN
Here's how I did mine. I wanted to be able to easily see and use the cruise control. To the left of the steering was too low for me, and the spot on the right isn't visible to me.
If you can't tell, this is the armrest piece with the power window/lock controls. The back of this plastic actually has two round raised things that I used as guides -- didn't even have to measure it out, just drilled the holes and wired it up. The red is on, black is set. Will also use the slide connects in the background just in case I ever need to remove the door panel. It goes in tomorrow, too dark out right now to be rooting around under the hood.
Old 01-31-2010, 06:58 PM   #105
Sodium Duck
╚══════════RN
Works great! Thanks to all who put this DIY together.
Old 02-02-2010, 07:22 PM   #106
Sodium Duck
╚══════════RN
The cockpit:
Cruise controls to my left.
CB, aftermarket stereo, 2009 black knurled control knobs, Ecometer and painted flat black trim to my right.
I love my Yaris.
If anyone wants my leftover resistors, I'll mail them to you, just PM me. I have 4 (comes in a pack of five).
Old 02-02-2010, 10:29 PM   #107
Sodium Duck
╚══════════RN
Resistors are gone.
Old 02-03-2010, 12:10 PM   #108
rcspott
Drives: 2008 Yaris HB Stick
2008 HB 3 Door Yaris Qustion
How much of the dash do you have to remove to see these connectors? Are some of them under the hood?
Thanks
rcspott is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
