#1 | |
Also, the pin will only fully insert in one position. If it is flipped over, it will go in most of the way, but will not seat. |
#2 | |
![]() Drives: Toyota Yaris Join Date: Apr 2007
![]() Drives: 2009 Yaris Sedan Join Date: Aug 2009
I posted yesterday the results of my install on my 09 manual sedan and at first I ran into the same problem with the repair terminal not fitting. I ripped the waterproofing sleeve trying to jam it in with fine needle nose pliers.
My post is at the end of http://www.yarisworld.com/forums/sho...=16188&page=30 On connector A21 there is a locking mechanism that you must push to one side to allow the terminal to slide in place and yes it would only go in one way, which happened to be the 4th position I tried. You then push back the white plastic slide piece and it will lock the terminal in place. |
#4 | |
It's the white thing at one end of the connector:
Lock latched: Lock Down.jpg Lock released: Lock Up.jpg Pop it with a small screwdriver from the side: Pop Lock.jpg |
well darn, I feel like an idiot now. Thanks CTScott
![]() Drives: 2007 2DR Yaris Join Date: May 2009
I just received my insulated wire from trdsparks... I will update the DIY this week end so that nobody breaks his A21 connector while trying to fit it... Thanks again to CTScott for figuring this one out (what would we do without you?) !
#9 | |
![]() Drives: 2007 yaris Join Date: Aug 2009
where do you buy this wire using the part number? |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
