![]() Drives: 2009 Yaris Sedan Join Date: Aug 2009
I posted yesterday the results of my install on my 09 manual sedan and at first I ran into the same problem with the repair terminal not fitting. I ripped the waterproofing sleeve trying to jam it in with fine needle nose pliers.
My post is at the end of http://www.yarisworld.com/forums/sho...=16188&page=30 On connector A21 there is a locking mechanism that you must push to one side to allow the terminal to slide in place and yes it would only go in one way, which happened to be the 4th position I tried. You then push back the white plastic slide piece and it will lock the terminal in place. |
#2 | |
![]() Drives: Toyota Yaris Join Date: Apr 2007
It's the white thing at one end of the connector:
Lock latched: Lock Down.jpg Lock released: Lock Up.jpg Pop it with a small screwdriver from the side: Pop Lock.jpg |
well darn, I feel like an idiot now. Thanks CTScott
#6 | |
EDIT: Just seated the terminal correctly, thanks again! Last edited by flutie98; 09-15-2009 at 06:39 PM. |
Just in case you are still curious, I found examples of locking mechanisms in the wiring diagram manual, page 14 through 16. Page 14 on the bottom left has some nice figures of a terminal with the "terminal retainer" both in the lock position and the "temporary" lock position, which is where I think a small piece of the terminal contacts the back of the retainer and holds it in place, but not as firmly as when you put the retainer in the lock position. There doesn't seem to be an example of a connector just like A21, but in the last figure on page 16 the connector on the left seems to have a somewhat similar retainer. Also, the third figure down on page 15 shows a terminal inserted into a connector with the waterproofing sleeve on it.
![]() Drives: 2007 2DR Yaris Join Date: May 2009
I just received my insulated wire from trdsparks... I will update the DIY this week end so that nobody breaks his A21 connector while trying to fit it... Thanks again to CTScott for figuring this one out (what would we do without you?) !
![]() Drives: 07 Yaris Join Date: Oct 2009
Stupid question
From reading the posts in this thread, it appears as though this does indeed work however I'm curious why the Rostra kit has is so complex in comparison?
I mean really, if it was just as easy as running one wire through the firewall why would they bother with all of the other ones? Is it that the Rostra one supports many models & years and this DIY trick is only for the 07 and 08? Also, I'm not sure if anyone answered this already, but would there be any reason I couldn't purchase an OEM cruise stalk and use the wires from this with this method? If it's safe and works then I'd rather spend $25 on the OEM stalk and a couple of bucks on some wire then $250-500 for an aftermarket kit. Thanks |
#10 | |
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
