Old 09-18-2009, 12:28 PM   #11
For the connection to the pin 40 wire, you are probably better off hitting it near the ECM and then coming through the grommet just above the ECM. Splice with a tap, or strip and solder, and then wrap with good (3M) electrical tape to seal.
To do the AD4 connection, you'd really need to remove the top of the dash. It's too far to reach from under.
For the ground connection, you can go down to the driver's kick panel, or you can ground to the metal support structure for the dash (there are a few bolts that you can get a terminal under).
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
