Old 09-19-2009, 02:40 PM   #1
Lafiro
Drives: 06 Yaris Sedan
I have the same problem. Remove the yellow wire and let it hang not touching anything.
Now turn on your fog lights, and they should work! Also make sure the ground is connected in the engine bay for the fog lights as well, don't forget that.
I also have Garms kit, it also came completely different then what the diagram asked for, with extra parts and cables. But at the end I got it working.
I am only stuck now wondering why it is that if I connect the yellow wire to the harness behind the light dimmer, that is doesnt allow anything to work.
Let me know what happens when you un-splice that wire to test what I said.
Old 09-19-2009, 02:55 PM   #2
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
did u connect the red wires coming from the fog light... using both? or just one red wire?
just curious....
I'll try what u said.
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 09-19-2009, 04:00 PM   #3
kuyachris84
I unspliced the yellow and it still won't turn on.
Can you take pictures of your install? How does mine compare to yours?
I wanna see how you setup he wires in the engine bay. I reconnected the ground in the engine to the negative battery. Did you end up using the white and black wire? Should i splice the black wire into the other ground wire?
Old 09-19-2009, 04:15 PM   #4
kuyachris84
I wanna know what you did here... i have the black and white wires (which came off the removed relay)... taped off and the two red wires connected to the two wires that go into pin1 and pin2.
Am I suppose to ground that second black wire?
I already have that other black wire connected to ground via battery.
Did you use only one red wire?
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
