#1 | |
Heart Up! Vitz
I guess not...Just alerting Lewis w/ his OZ cluster.. |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
#3 | |
Heart Up! Vitz
Learned in a cadillac de ville? Shit....i learned in a 90' ford escort wagon ![]() Here's hoping Lewis, gets the cluster on Tuesday. |
#4 | |
The brake fluid warning level wire (purple) and fog light indicator wire (red) need to swapped from pin 2 to pin 7 on that right connector. The alternator indicator wire (light blue in pin 1) needs to swap with the left turn signal wire (light green in pin 8). The check engine light wire (black in pin 4) needs to move to pin 5. The beam indicator wire (pink in pin 11) needs to swap with headlight power wire (gray in pin 14). The right turn signal wire (brown in pin 15) needs to move to pin 10. (the white in pin 10 gets pulled an taped off as there isn't a washer level low indicator). There's no input for the dimmer rheostat, hence the no dimming, but the JDM digital clusters have a magic button press sequence of the odo button that adjusts the dimming level. The JDM analogs may have the same. Put the odometer in "odo" mode. Press and hold the odometer changing button for 3 seconds. Auto dimming will toggle on or off. |
#5 | |
I applaud your work. What do you do for a job or are you that rich from selling ideas you sit at home doing drywall and modding Crashy?
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
WRW76
Drives: Yaris Join Date: Nov 2008
Just call me Ray, better?
sedan de ville would be se ville lol
Our off road vehicle
Drives: 2009 Yaris 3dr Join Date: Apr 2009
remember guys- a watched pot never boils
the package will arrive when the post office and customs say it will arrive! luckily the next couple of weeks are mostly open for me so if Scott's schedule is flexible we can do this pretty quickly when it comes we are about 2 - 2 1/2 hours drive from one another so the trip is not a big obstacle .......and after Scott if all works out there - we have my trip to my friendly Toyota dealer to do the Techstream flash- to me the job isn't done until I see mph on the screen with the correct odometer miles this is like a soap opera- patience will definately be needed- me thinks I will be celebrating my new cluster on Thanksgiving! Last edited by Lewis; 10-12-2009 at 06:44 AM. |
Heart Up! Vitz
My cluster came from a RHD.
Scott, just for clarification, Doing the swapped wiring configuration from what you've explained to me above....will that get my passenger seatbelt & passenger airbag light indicator working? My turn signals work correctly, the light beam indicator in the cluster (different icon than US icon), turns on when i have car's lights on perfectly. Now if I do your wiring swap config. would that mess up things already working properly ie: turn signals, light indicator on cluster showing, etc..? As for the dimming, thank you for the help. I will try that out when the whole flashing of the miles to accurate kilos gets done... P.S. I forgot to mention....E-brake icon stays on in the cluster even though I have the e-brake all the way down LOL.... Techstream update: Toyota dealers said they can't flash my cluster. The mechanic there said himself they dont do it all, comes from factory. They send all there clusters/gauges (that need to be calibrated) out to a company that burns the odometer readings into the clusters for Toyota dealerships.....and then ships back to the dealers. I have to go to this company to get it done...weird right? Will update soon (I'm going either tomorrow or Wednesday)....and if the company is good, and for some reason Lewis's dealership doesnt do it, I will work w/ Lewis to get it done through this company... Company URL: http://www.paspeedo.com/ |
#11 | |
Hmmm. So, beam, and turn signals work. How about the headlight indicator and the check engine light? If the headlight indicator doesn't work, I would do the 9 and 16 swap. The 2 and 7 swap should fix the brake light issue. |
Heart Up! Vitz
I honestly have to say, CTScott the smartest fucking person on here, maybe ever..that I've come to known....seriously. Very cool helpful information....deserves an award :)
genius
Heart Up! Vitz
CTScott, i dont want to hijack Lewis's thread....so here is a new thread for my arising problems.
Thanks, really need your help now desperately.... http://www.yarisworld.com/forums/showthread.php?t=23127 |
.....Kioshi- it was fine with me to read this here because remember Australia is right hand drive too so your experience may be all too relevant to the OZ cluster.
Furthermore if my experience in recieving parcels from Europe is any indication it might be a good while until I'll be writing about how the OZ cluster works out. I can just update folks on bagels and coffeee for so long before they die of boredom. |
Tic toc tic toc tic toc. Counting the seconds as they go by.
Update- no bagel this morning, but a nice cup of tea. Oh by the way- package not here yet.
Qantas forgot to pay their fuel bill? Or perhaps the cute little Koala Bear ate my package in the cargo hold? My arrival prediction- any day day now! |
Heart Up! Vitz
You guy's didnt get a tracking number for this?!
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 09:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 12:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 10:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 10:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 11:37 AM |
