Old 10-03-2009, 01:23 AM   #1
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Pretty sure the accessory belt is considered a wear and tear item and not covered under any warranty. Mine went at around 50,000km so I guess its just what type of environment you live in. You can try asking the dealer to replace but my guess is they will try and charge you.
devinlamothe is offline   Reply With Quote
Old 10-03-2009, 09:32 AM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks buddy - ur right; i looked clearly and it says "timing chain/belt" not accessory belt...........this totalllly sukssssss. gonna cost me like 100 dollars including belt.
Yawesh is offline   Reply With Quote
Old 10-03-2009, 10:17 AM   #3
Belt will cost peanuts at an auto parts store. Replacing it is simply a matter of loosening the alternator.
Old 10-03-2009, 10:20 AM   #4
The belt is very easy to change yourself, and if I remember right, I only paid $15 for the belt at Napa auto parts. You just have to loosed two bolts on the alternator mount, slip the old one off, slip the new one on, put a little tension on the alternator, and tighten the bolts. It was literally a 10 minute job to put a new one on Crashy.
Old 10-03-2009, 11:40 AM   #5
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks guys, gonna try myself. i've always been an oil change specialist lol.
Old 10-03-2009, 11:41 AM   #6
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
just need regular rachet and socket right? u remember what mm is it? heh. thanks. i think our drain plugs are 14mm i forgot. should i wd-40 the bolts on the alternator first?
Old 10-03-2009, 01:03 PM   #7
Regular rachet/socket correct.
Upper bolt in banana bracket is 12mm. Very easy to loosen.
Lower bolt is 14mm. Can sometimes be difficult and may require a little 'grunt' behind it.
Mark with a pencil the bolt position on the upper bracket so that you know where to bring everything back to for proper tension with the new belt.
Old 10-03-2009, 02:05 PM   #8
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
