Old 10-03-2009, 01:03 PM   #8
Originally Posted by Yawesh View Post
just need regular rachet and socket right? u remember what mm is it? heh. thanks. i think our drain plugs are 14mm i forgot. should i wd-40 the bolts on the alternator first?
Regular rachet/socket correct.
Upper bolt in banana bracket is 12mm. Very easy to loosen.
Lower bolt is 14mm. Can sometimes be difficult and may require a little 'grunt' behind it.
Mark with a pencil the bolt position on the upper bracket so that you know where to bring everything back to for proper tension with the new belt.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
