The belt is very easy to change yourself, and if I remember right, I only paid $15 for the belt at Napa auto parts. You just have to loosed two bolts on the alternator mount, slip the old one off, slip the new one on, put a little tension on the alternator, and tighten the bolts. It was literally a 10 minute job to put a new one on Crashy.
#2 | |
![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
#3 | |
#4 | |
Upper bolt in banana bracket is 12mm. Very easy to loosen. Lower bolt is 14mm. Can sometimes be difficult and may require a little 'grunt' behind it. Mark with a pencil the bolt position on the upper bracket so that you know where to bring everything back to for proper tension with the new belt.
#5 | |
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Accessory Belt change. When?? | mhkritzinger | DIY / Maintenance / Service | 12 | 10-23-2009 02:58 PM |
| The Accessory belt? | N9QGS | DIY / Maintenance / Service | 4 | 02-12-2009 11:05 PM |
