Old 10-03-2009, 01:03 PM   #1
Originally Posted by Yawesh View Post
just need regular rachet and socket right? u remember what mm is it? heh. thanks. i think our drain plugs are 14mm i forgot. should i wd-40 the bolts on the alternator first?
Regular rachet/socket correct.
Upper bolt in banana bracket is 12mm. Very easy to loosen.
Lower bolt is 14mm. Can sometimes be difficult and may require a little 'grunt' behind it.
Mark with a pencil the bolt position on the upper bracket so that you know where to bring everything back to for proper tension with the new belt.
Old 10-03-2009, 02:05 PM   #2
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
thanks
Yawesh is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
