Old 10-13-2009, 08:43 AM   #1
1stToyota
1stToyota's Avatar
What happens if it opens when youre driving? (nevermind I know what happens!) Hard to improve on a ten cent bolt. (and its free!)
That's only a concern with the Fumoto
The Fram has no lever, it has the internal pressure seal that only gets activated when you screw on the drain hose during an oil change, plus it also has the redundant outer seal and screw on cap, and it's a lot smaller.
Most Fram SD p/n's @ amazon are less than $8.00, over $20.00 less than the Fumoto @ amazon
I believe ours is the SD-3 [M12x1.25], not a M14x1.50 as previously mentioned.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-13-2009, 10:25 AM   #2
It is 12mm-1.25.
I put the Fumuto F-103 on my Yaris and my Xterra (same size one as the Yaris). I was very impressed with the quality and with how hard it would be for the valve to be accidentally opened. it has a ball valve, and on top of that it has a significant spring that you have to press the lever against to open the ball valve.
It's nice being able to drain the oil without getting a drop on your hands.
Old 10-13-2009, 10:53 AM   #3
1stToyota
1stToyota's Avatar
It is 12mm-1.25.
I'm thinking about getting something, probably the Fram, because I'll be doing UOAs on my next 2 oil changes and figured it'd be easier to get samples with a drain device.
The Fumoto lever doesn't scare me, but if it hangs a little lower than the pan I was afraid that a board or similar debris could hit the entire valve itself.
2008 Scion xD
Old 10-13-2009, 11:12 AM   #4
Here's what mine looks like.
From the front (barely visible between the two bumps):
From the side (If you put a level across the bottom most point of the oil pan it sticks down about 1/2" below the bottom of the pan):
Old 10-13-2009, 12:36 PM   #5
bronsin
bronsin's Avatar
Attachment 29144
Attachment 29145
Hmm I gotta think hitting something on the freeway like a tire carcass is going to make your day a lot more interesting!
Old 10-13-2009, 02:30 PM   #6
1stToyota
1stToyota's Avatar
Agreed. Looks like a big ol' bulls-eye to me.
I just ordered the Fram SD-3 [$12.89, shipped], I'll post up some pictures when I get it installed.
2008 Scion xD
Old 10-13-2009, 04:47 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
got a link to the exact unit?
If I do this.... it only makes sense for me to do it to both my yaris & the 00 subaru legacy the better half drives.
The fram would most likely be fine, and if I could get two shipped for under $30, that saves me enough to fill my tank up with gas.
$30 savings is significant... I doubt fram would sell a product that was bound to get them sued multiple times because it easily broke when it hit dibris, or randomly leaked.
Old 10-13-2009, 11:42 AM   #8
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The valve can NOT accidentally open. You can open and close the valve to get samples. You can control a valve. You can not sample as easily with the Fram.
Old 10-13-2009, 12:26 PM   #9
1stToyota
1stToyota's Avatar
Look above. The Fomoto is a much larger target, that's what I worry about, again, not too worried about the actual lever. Any large item like a board will knock that valve off, easily. I just worked on a Lexus that got its transmission dipstick cut in two, ruining the transmission, and it was hidden waaaay better than the exposed Fumoto valve. The Fram valve is a whole lot smaller target. And you can sample very easily with the Fram. Their drain hose threads on, so simply control how much you want to tighten, same as how much you want to pivot the Fumoto lever.
2008 Scion xD
Old 10-13-2009, 01:01 PM   #10
yaris-me
Learn to Relax
Obviously you want a Fram. So why not, just buy it. You won't be happy otherwise.
Old 10-13-2009, 01:21 PM   #11
1stToyota
1stToyota's Avatar
No, I want the one that will be least likely to cause me headaches and looks the least like a sore thumb...just sorry that Fram looks like the smarter choice for me [and I'm not the only one], and even worse that it's only $8.00 at amazon, but the Fomoto does have the much more exotic sounding name.
2008 Scion xD
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
