Old 10-13-2009, 11:42 AM   #17
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Originally Posted by 1stToyota View Post
That's only a concern with the Fumoto
The Fram has no lever, it has the internal pressure seal that only gets activated when you screw on the drain hose during an oil change, plus it also has the redundant outer seal and screw on cap, and it's a lot smaller.
Most Fram SD p/n's @ amazon are less than $8.00, over $20.00 less than the Fumoto @ amazon
I believe ours is the SD-3 [M12x1.25], not a M14x1.50 as previously mentioned.
The valve can NOT accidentally open. You can open and close the valve to get samples. You can control a valve. You can not sample as easily with the Fram.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
