Old 10-13-2009, 12:26 PM   #1
1stToyota
1stToyota's Avatar
Originally Posted by yaris-me View Post
The valve can NOT accidentally open. You can open and close the valve to get samples. You can control a valve. You can not sample as easily with the Fram.
Look above. The Fomoto is a much larger target, that's what I worry about, again, not too worried about the actual lever. Any large item like a board will knock that valve off, easily. I just worked on a Lexus that got its transmission dipstick cut in two, ruining the transmission, and it was hidden waaaay better than the exposed Fumoto valve. The Fram valve is a whole lot smaller target. And you can sample very easily with the Fram. Their drain hose threads on, so simply control how much you want to tighten, same as how much you want to pivot the Fumoto lever.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-13-2009, 01:01 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Obviously you want a Fram. So why not, just buy it. You won't be happy otherwise.
Old 10-13-2009, 01:21 PM   #3
1stToyota
1stToyota's Avatar
No, I want the one that will be least likely to cause me headaches and looks the least like a sore thumb...just sorry that Fram looks like the smarter choice for me [and I'm not the only one], and even worse that it's only $8.00 at amazon, but the Fomoto does have the much more exotic sounding name.
2008 Scion xD
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
