Old 10-19-2009, 11:47 AM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
I would totally go with CTScott's method with the Indicator Module. It's cheap and looks just as good as the Kits, or OEM installation. As long as you place the LED where you want it. I actually put mine in the Gauge Cluster to make it look more OEM, but I think it looks better than OEM myself. I'm sure if you take the time and have the skill you could scratch the OEM icon on the black cluster cover and it would look totally OEM.
The module does exactly what it says in the "CAN WE DO THIS" thread post #398. The light comes on for 1 second on power up and then works like a charm when in use. I equipped it with a white "12V ready" LED, but you can use whatever color you want.
I've noticed only one thing with your Module CTScott. When I hit the on/off switch two times really fast the CC reads two pushes, but the Module only reads one and actually inverts the LED. So you have to hit it again twice really fast to reset it. Also when I turn on my HID headlights there is a quick power drain that resets the module (the light comes on for a second and then the LED is reversed again because the drain doesn't reset the CC) But this only happens if I turn my CC on before the headlights. So if I hit the lights first I have no problems.
It's totally invisible until you hit the switch...see that little white dot?
Video of it working...
http://s236.photobucket.com/albums/f...t=CIMG7073.flv
My Car Rules!
nickhjort is offline   Reply With Quote
Old 10-19-2009, 11:56 AM   #2
The quick press issue is due to switch deboucning. I found that the radio shack switches require almost 100ms of debouncing. With higher quality switches the debouncing can be significantly reduced.
I can't believe that the HIDs draw it down that much. You may want to consider a heftier battery or you might run into some problems. In doing some experimentation I found that the ECM becomes very flaky if the battery voltage sags below 9 volts.
Old 09-02-2012, 12:37 AM   #3
chanka
Drives: Toyota allex
Cruise Cotrol
Hi Scott,
If I don't have cruise control in my 08 yaris (M5) (New Zealand New) hatch how can I fit CC ?
Cheers.
Chanka
chanka is offline   Reply With Quote
Old 09-02-2012, 06:56 AM   #4
Originally Posted by chanka View Post
Hi Scott,
Cheers.
Chanka
For your car you would need a complete aftermarket system, since your ECM does not have the functionality built in.
Old 03-11-2013, 08:42 AM   #5
fascar228
Drives: vitz RS 1.5L 2006
Hi All,
I have a 2007 Vitz JDM 1.0L can the Cruise control mod work for my vehicle....
fascar228 is offline   Reply With Quote
Old 10-19-2009, 05:51 PM   #6
Taboolie
Drives: 07 Yaris
Ah you're right, I didn't consider that you could mount it in the instrument cluster and it be hidden. Looks pretty sweet btw.
I had some mental picture of some half ass LED sticking out of the dash somewhere. As it is my wife's worried I'm going to somehow mess up her car :)
Even with the LED kit you have, I'm still less comfortable taking apart trim pieces and the entire dash then routing some harnesses and tapping in to some wires under the steering column. I've had bad luck previously with plastics breaking.
The car is only 4 days old, to me at least, so mentally I'll just think it was another $200 for cruise control when I bought it. I'd have paid that.
Taboolie is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
