Old 10-24-2009, 03:00 AM   #1
YarisSedan
Drives: 08 Yaris Sedan
Probally loose connection resulting in vacuum leak. Or the seal for the MAF sensor is not seated correctly. If the CEL is on its most likely MAF sensor related. I would wiggle all the hoses and tighten the clamps. Make sure the breather hose is connected correctly to the tubing and if everything looks good disconect the negative battery for a few minutes and reconnect and seeif they light comes back on. If it does you may have damaged the sensative MAF sensor. You can never touch the wires or get any contamination on them.
Old 10-24-2009, 03:21 AM   #2
Mr Yarisman
Mr Yarisman's Avatar
Drives: Vitz
When i install the AFE intake the engine lights came on then I drove it for day then came off now is on again.
Mr Yarisman is offline   Reply With Quote
Check engine code 456 on brand new '09 kameele DIY / Maintenance / Service 3 10-14-2009 11:12 PM
Got engine check light :( jmew0ng DIY / Maintenance / Service 15 07-01-2009 10:09 PM
Anyone get the Check airbag light to go away when you installed racing seats or wheel wholenizz Cosmetic Modifications (Exterior/Interior) 1 06-17-2009 08:14 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
