Old 10-27-2009, 01:17 AM   #37
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
LMFAO....at the pics.
Welcome to the forums H3LlIon....enjoy your stay and check out the other sections of this forums, make yourself a home :)
Old 10-27-2009, 01:46 AM   #38
fmicle
fmicle's Avatar
Drives: 2007 Yaris LB
This thread is hella funny.
The truth is, it would be kinda fun to have a bigger tank on the Yaris and have a range of 1,000 miles or something. Imagine the conversation: aren't you afraid you're going to get stuck in the desert? No, I can cross the Sahara in this thing on one tank of gas.
Second, too bad you can't do anything with that deer. If you hadn't written the explanation, I would have guessed it must be just perfect, the deer already tenderized, just fire up the BBQ...
fmicle is offline   Reply With Quote
Old 10-27-2009, 11:03 AM   #39
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
eww, too much weight. I've thought of getting a smaller tank or fuel cell to eliminate some of the weight of the gas. Weight matters a ton to fuel mileage. The less you can have, the better.
Colin Chapman disciple
Old 10-27-2009, 11:38 AM   #40
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
This is pretty funny. BTW - I don't think it would be that hard to swap a larger-capacity tank from another Toyota vehicle. you'd need to figure-out the max dimensions that would safely fit and ensure that the pump/pickup were either the same or could be fitted to your existing wiring/fuel lines. I think the Camry and/or Corolla have similar-but-larger tank setups.
Old 10-27-2009, 11:57 AM   #41
H3LlIoN
Drives: '09 Yarrrr hatch
I am not amused. Just got back from the dealership...$2200 worth of damage.
H3LlIoN is offline   Reply With Quote
Old 10-27-2009, 12:03 PM   #42
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
I don't think I would like to be around when he drills a hole in the fuel tank, the pyrotechnics could be quite spectacular...
IF one can find a tapped hole in the tank, it is possible to devise a "chicken hopper" tank as an auxilliary, but whether it would work with these sealed systems or not, I can't say. Best to just get out of the car after 300 miles anyway...
Old 10-27-2009, 12:57 PM   #43
b_hickman11
Drives: 08 Sedan
It was a joke dude
b_hickman11 is offline   Reply With Quote
Old 10-27-2009, 02:03 PM   #44
H3LlIoN
That's kind of what I was thinking. My roomate is a Toyota tech, got him checking in to it for me.
Old 10-27-2009, 02:41 PM   #45
Loren
What?
Loren's Avatar
Okay, so you still might have to fill up as often as you did with your larger vehicle. You can still get a little (or a LOT) of joy from the fact that when you do fill up, instead of costing you $80, it's going to cost you less than $30. You have to admit that's pretty cool!
Old 10-27-2009, 02:56 PM   #46
fmicle
fmicle's Avatar
That is totally cool With my Jeep Cherokee, I got 400 miles on a tank of gas for $60, with the Yaris, I'm getting the same for $30.
As others have said earlier, it would add too much weight and for daily driving it wouldn't make sense. But I still think crossing the Sahara on one tank of gas would be cool too
Old 10-28-2009, 12:30 AM   #47
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Wink
I think crossing the US would be even cooler
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 10-28-2009, 12:43 AM   #48
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Well, yeah, I'd like to have a nuclear reactor and just change the fuel in 20 years or so.
Old 10-28-2009, 01:06 AM   #49
H3LlIoN
QFT. Empty to S.A.F. the other day was $27usd.
Old 10-28-2009, 01:28 AM   #50
fmicle
fmicle's Avatar
That would be a cool project... Remove the rear seats and make half the interior a big gas tank. That should get you from coast to coast without refueling
Old 10-28-2009, 01:50 AM   #51
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
well lets see... New York to Los Angeles is 2,776 mi shortest route according to google maps... at about 40mpg highway (maybe higher but to be on the safe side...) that's 69.4 gallons of gas, minus 11 gallons already onboard that's 58.4 gallons you would need to have extra... I wonder if a 60 gallon tank would fit in the back of a Yaris.
Old 10-28-2009, 01:54 AM   #52
CtrlAltDefeat
I ♥ Yaris
The weight of the extra gas would be about 370lbs, so it would be like having a couple of 185lbs people in the back...
Old 10-28-2009, 03:28 AM   #53
advocate
Drives: car
Which would easily drop your MPG to 35. Maybe less.
I don't doubt you could fit the gas into the car someway.
What I wonder about is whether or not the car is capable of driving 3,000 miles non stop?
Old 10-28-2009, 05:11 AM   #54
CtrlAltDefeat
I ♥ Yaris
well 35mpg at the start, but more like 45mpg near the end when fuel is lower (averaging 40 I'd hope...) as far as it running 3000 non-stop, I can't imagine why not, you wouldn't be running at redline or slinging the car side ways and such that would cause something to break... barring any silly bad luck breakdowns...
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
