Old 10-26-2009, 08:36 AM   #1
H3LlIoN
Drives: '09 Yarrrr hatch
Angry How the hell am I supposed to drive past gas stations with only an 11.1 gal tank?
Yeah. Probably a dumb question. I want to increase my fuel capacity so I can go further without stopping. As is it, I can drive just about as far as my 11mpg Yukon makes it before IT runs out of fuel. What's the fun in that? Anyone have any thoughts?
Flame away.
And yes, my yukon really does only get 11mpg. The Yaris averages me out to mid 20's though.
H3LlIoN is offline   Reply With Quote
Old 10-26-2009, 08:42 AM   #2
H3LlIoN
Forgive this thread. I've been up for 22 hours. I know it's not doable, at least according to my roomate, the Toyota master mechanic.
It'd just be so super awesome to spend the same amount of money as it takes to fill the yukon, yet drive around for 1200 miles before stopping again. only filling up 10 times a year though doesn't jive to well with big oil.
Old 10-26-2009, 08:47 AM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I usually get around 370-400 miles on my 10 gallon fillups. I pass quite a few gas stations with that. A much larger tank would cut your mileage due to added weight, and you would be more likely to encounter problems with fuel going stale, accumulating moisture or being out of season with the changing fuel blends for different temperatures.
Old 10-26-2009, 08:55 AM   #4
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
Same here, I have never had less than 39MPG(first tank) and best of 44MPG. I guess if you want to pass more fuel stations you need to slow down a little. I know its no fun doing that, buts its the easiest way I can think of. Then you can get about 420miles out of 10 gallons or so.
Peace
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 10-26-2009, 08:59 AM   #5
H3LlIoN
Yeah my truck will go 400 if I'm real easy and on the highway alot, so I'm passing the same gas stations, just at a higher cost. I can't imagine the weight of added gasoline could affect it that much...I don't have an exact figure, but I'm guessing gas is ~ water, which is 8#/gal.
I just think it'd be sweet to go further. My mom has an excursion with a 44 gal tank, diesel. When she fills that bad boy up, the computer regularly will calculate in the 700-800 miles to empty range...best I've ever done was 730, and it's awesome to be able to drive forever with out stopping. I made two round trips this month to the blue ridge from hampton roads, and still had fuel to run around town looking for the cheapest diesel.
Hah could you imagine a yaris with present mpg and a 44 gal tank? ~1500 miles to empty, lol.
Old 10-26-2009, 09:01 AM   #6
H3LlIoN
Eh I think it probably has something to do with the 230lbs that I add to the load, plus all the crap that I leave in my car on a daily basis. :-P
Old 10-26-2009, 11:51 AM   #7
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
LOL..You're making excuses, if you want the range you will have to slow down.
I'm 260-280 lbs and my range is about 450-480 or so before I fill up again.
Old 10-26-2009, 12:28 PM   #8
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Seems to me there is an "industry standard" for fuel tank capacity, usually works out to a range of 300-400 miles. Some vehicles have larger tanks installed for extra range, but nearly every car I've had in the last 55 years worked out to about the standard.
This is why I giggle a bit when someone says the made it from x to y on 1/2 a tank of gas; so does everyone else. Ask what the tank capacity is, and most have no clue...
Old 10-26-2009, 12:32 PM   #9
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Try riding a motorcycle with a 1.9 gallon tank. Get back to me after.
The Yaris' 11.1 gallon tank and MPG make the small tank a moot point. I rarely have to get gas.
Old 10-26-2009, 12:37 PM   #10
H3LlIoN
jesus. I've been in this particular forum for 5 hours and already I'm lead-footed AND burning the wrong gas. Yeehaw.
Old 10-26-2009, 12:50 PM   #11
RUFFSTUFF
Drives: 2009 TOYOTA YARIS SEDAN
Flame away.
No need to flame. It's obvious what your issues are.
RUFFSTUFF is offline   Reply With Quote
Old 10-26-2009, 01:12 PM   #12
chongopants
Drives: 2007 Yaris Hatchback
Send a message via AIM to chongopants Send a message via MSN to chongopants
drive by with an 11 gallon tank b/c you only weigh 2k lbs... I get over 400miles to a tank...
chongopants is offline   Reply With Quote
Old 10-26-2009, 01:53 PM   #13
mr9865
$10.25/hr frying chicken
mr9865's Avatar
Drives: 2012 Yaris L
Is refueling really that hard?
mr9865 is offline   Reply With Quote
Old 10-26-2009, 03:14 PM   #14
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
I understand the OPs sentiment... It would be awesome to put our outstanding MPG to use on a huge tank of gas, and just drive forever. The "passing up gas stations" phrase is a bit of a misnomer, as smaller vehicles generally have smaller gas tanks and similar ranges to larger vehicles. As far as the effects of a larger tank on a Yaris, if you were talking about a 44 gallon tank (like 4x the size of the standard tank), I imagine Yaris Hilton and the others would be correct about stale gas and water buildup. The weight would also be a factor of course. I do, however, think that a 20 gallon tank might work without too much water/gas problems. The extra gas (9gal) would weigh about 55.35 lbs (which really isn't that much) at about 6.15 lbs/gal (per wiki answers) and range would be almost double. The problem with that is: where in our tiny subcompacts would you put that huge tank, and if you took a hard turn would the back end kick out sideways when all 120lbs of gas suddenly sloshes sideways?
I apologize on behalf of the rest of YW for the flames. Mpg is a hotly debated topic here, so you really picked a good one to start with. So welcome to YW, and just don't take it personally
Last edited by CtrlAltDefeat; 10-26-2009 at 03:28 PM. Reason: typo and slight recalculation on the tank sizes/weight
Old 10-26-2009, 03:54 PM   #15
b_hickman11
Drives: 08 Sedan
Flame away.
Go to Wal-Mart. Buy a 12 Gallon Fuel Container for $49.96 http://www.walmart.com/catalog/produ...ct_id=11071152 Strap dat hoe in your truck. Drill a hole in the left side of your trunk, towards the fuel door. Run some type of fuel line from your newly installed tank to the fuel inlet. Get you a pump. Install it.
Old 10-26-2009, 03:58 PM   #16
I can't imagine watching the dollar signs roll by while pumping 44 gallons into a vehicle. Filling up from empty for less than $30 with my Yaris is much more palatable then dropping over $100 at one time at a gas station.
Old 10-26-2009, 04:16 PM   #17
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I'll put that 11 gals in my car and at legal freeway speeds (60mph)easily drive 6 to 7 hours with out stopping.
Old 10-26-2009, 04:30 PM   #18
supmet
Drives: 2007 4 Door Yaris
fuel cell in the trunk.
And I don't know how many more red flags you guys need for a troll... I mean comparing an excursion to a yaris in the FE forum?
