Old 10-30-2009, 02:00 AM   #1
dreamteam
Drives: 2008 Yaris
I agree with Toast, had the same problem with my defrost, pulled the fuse on the air.
It's clearly marked and easy to get to........liked the results so well, that I pulled the fuse on the wife's '07 corolla. Suddenly, we are both getting better mileage!
Now, this won't work so good if you live in a hot climate........, up here, I won't have to put that fuse back in until spring.
dreamteam is offline   Reply With Quote
Old 10-30-2009, 12:42 PM   #2
People often forget that the A/C is turned on automatically with various settings. Pulling the fuse definitely works as an absolute verification that it is off, but in the case of the Yaris, doing the mod mentioned above definitely turns off the automatic mode, but still lets you turn it manually (without stopping to put the fuse back in).
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Help Needed: Unlink A/C to Defroster stran DIY / Maintenance / Service 25 01-09-2009 01:50 PM
DIY Requests. TinyGiant DIY / Maintenance / Service 13 10-29-2008 10:39 AM
