Old 10-31-2009, 06:21 PM   #1
mohamedmohsen2000
Drives: Toyota Corolla 2002
What should I do with my radiator coolant to remove this bubbling noise ??
should I flush the coolant completely at a workshop then fill it with new coolant ?
I am still confused, and note that the noise is getting louder and lasts for longer time now as the weather is getting somehow cold. I believe there is a relation between the weather and the sound, so it can't be any synthetic oil, it must be water.
Then you are right about the coolant flowing in the heater core. thanks for description AmyV.
Now, we still need the solution.
Thanks
mohamedmohsen2000 is offline   Reply With Quote
Old 10-31-2009, 08:36 PM   #2
bronsin
bronsin's Avatar
Thanks
Ok check your coolant level. Remove the radiator cap WITH THE ENGINE COLD! If the radiator is full up to the neck and the overflow bottle is also full of coolant...the noise isnt a low coolant level causing air to circulate through the system. But if there isnt coolant to the top of the radiator its an easy matter to add it. Put the cap back on and drive the car for half an hour or so. Let the car sit for an hour so it cools down. Dont try to open the raditor cap of a hot engine! When its cool to the touch remove the cap and check the level again. Repeat this until the radiator is full. Fill the overflow bottle too if its not reading full.
Good luck and tell us what happens!
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 12:40 AM
Weird door locking problem, electrical? davembfan General Yaris / Vitz Discussion 19 09-30-2009 02:50 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
