That Anime Guy
I'm wondering if I can't take the individual throttle bodies off an MR-2 or AE86 and put them on the Yaris with a custom bracket and throttle cable.
Drive-by-wire sucks.
#2 | |
![]() ![]() ![]() Drives: Polar White Hatch Join Date: Nov 2006
N/A mods will leave you broke and underwhelmed. With the amount of money it would take to get the car into the 16s you could buy another car that has potential to go fast.
ChinoCharles Intake supporter. |
#3 | |
Its one of those things that could probably be flashed into the ecu.
Fitting ITB's won't be a problem, Dan actually sells a premade "kit" for this:
![]() www.danstoy.net You can either remap the ECU to accept the mechanical throttle and TPS signals or you can swap ECU's to a standalone (TEC3 on the scion above) or run the OEM Toyota AE101 or AE111 ECU's. Keep in mind all of this won't do much for power, believe the red Scion only makes ~130 crank HP, but they did this more for the looks, sound and they are now planning to turbo the car. If your plan is to go N/A on this engine, the easiest way to do this is to pick up a spare junk motor for under $500, then experiment with cams, and valvetrain, since that is where the biggest restriction is. You can then bump up compression and with beefier rods/bearings/pistons raise rev limiter and making some more top end. I would budget somewhere in the range of $4-$7K for the engine alone. |
#5 | |
#6 | |
I'm not saying this is the optimal setup, and most times, if you're going to the trouble of all these mods, You'll likely run an aftermarket EMS setup, but it is possible and people do run their cars like this. |
#7 | |
I know that electromotive used to make a complete aftermarket ITB and ecu setup for the Dodge Neon. After reading that above listed link I don't think anyone is going to want to drop any money on n/a mods. The question of the hour should be what motor can be swapped into the chassis. Hopefully some company comes up with swap mounts for the Celica motor.
#8 | |
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
Let me add that forced induction is the best way to make some ponies and still maintain great driveability |
