Old 10-01-2009, 11:14 AM   #1
birdman
Drives: '08 Blazing Blue Yaris LB
TPMS sensors
Does anyone know where I could purchase an extra set of TPMS tire sensors for my other rims? If I can find a source that is cheap enough it might be good to add them and keep the system fully functional.
birdman is offline   Reply With Quote
Old 10-01-2009, 11:20 AM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
www.tirerack.com
Originally Posted by xnamerxx
you nailed it sir.
Old 10-01-2009, 11:24 AM   #3
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
also, I've seen them on ebay for good prices. You'll need to check with the dealer, but I think some other toyota/scion models use a compatible sensor. I don't think it will work with the sensors that send individual tire pressure info to the car, but I really don't knwo for sure.
Old 10-01-2009, 11:49 AM   #4
If you get an extra set, you'll need to go to the dealer or tire shop when you switch your tires over, as the Yaris' TPWS can only remember one set of four transmitters.
At one point I was looking into creating a module to intercept the comm from the sensors and if all is OK, relay the data on, as if it was from the original set of sensors. After I found out how slow the system responds and how low the pressure needs to be to cause a warning, I decided it wasn't worth the effort and instead developed my bypass solution.
Old 10-01-2009, 12:42 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
i use a special TPMSFRP system, works VERY well
you nailed it sir.
Old 10-02-2009, 09:18 PM   #6
birdman
Scott you are awesome dude!
Old 10-02-2009, 09:20 PM   #7
birdman
Tamago, For selling parts out of the ordinary you are extraordinary too!
Old 10-02-2009, 09:21 PM   #8
birdman
Special TPMSFRP? Care to elaborate?
Old 10-02-2009, 09:27 PM   #9
birdman
There seemed to be a lot of nuances to the TPMS switch mod as that discussion grew. Which one was the easiest. Not for you, but for dummies like me?
Old 10-02-2009, 10:20 PM   #10
Look at the thread from the end back. The third pass ended up being the easiest and works perfectly.
Old 11-08-2009, 12:15 PM   #11
Tamago
Tamago's Avatar
Drives: ZZW30
Tire Pressure Monitoring System For Responsible People
hehe
you nailed it sir.
Old 11-08-2009, 12:26 PM   #12
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Old 11-09-2009, 06:37 PM   #13
birdman
Thanks for all the information!
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 02:20 AM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 03:00 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 10:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 01:18 AM
TPMS TinyGiant Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-22-2008 04:57 PM
