![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
TPMS sensors
Does anyone know where I could purchase an extra set of TPMS tire sensors for my other rims? If I can find a source that is cheap enough it might be good to add them and keep the system fully functional.
Reluctantly Crouched...
Drives: 2008 Yaris HB M/T Join Date: Oct 2008
also, I've seen them on ebay for good prices. You'll need to check with the dealer, but I think some other toyota/scion models use a compatible sensor. I don't think it will work with the sensors that send individual tire pressure info to the car, but I really don't knwo for sure.
#4 | |
At one point I was looking into creating a module to intercept the comm from the sensors and if all is OK, relay the data on, as if it was from the original set of sensors. After I found out how slow the system responds and how low the pressure needs to be to cause a warning, I decided it wasn't worth the effort and instead developed my bypass solution. |
i use a special TPMSFRP system, works VERY well
Scott you are awesome dude!
Tamago, For selling parts out of the ordinary you are extraordinary too!
Special TPMSFRP? Care to elaborate?
There seemed to be a lot of nuances to the TPMS switch mod as that discussion grew. Which one was the easiest. Not for you, but for dummies like me?
Tire Pressure Monitoring System For Responsible People
hehe
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
Thanks for all the information!
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| Tire rotation: Does TPMS recognize tire position? | jcdrotos | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 17 | 03-17-2011 02:00 PM |
| tpms compatibility? | bwong2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-11-2009 09:33 AM |
| TPMS Gauges - do they exist? | Sodium Duck | DIY / Maintenance / Service | 24 | 03-01-2009 12:18 AM |
| TPMS | TinyGiant | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 10-22-2008 03:57 PM |
