Old 11-13-2009, 07:39 PM   #1
Originally Posted by yoxx View Post
yes is their nitrous brand, and yes it come with a sensor but i dont want to drill a hole on my car for the sensor, but if i can get around it and NOT drill a hole on my car will be better
now for the sensor it only have one cable and you give me two, so i didnt know on wich one to plug it in so i havent test it on any of them yet
now i gues that you r familiar with the gauge that i got, is there a extra hole on the car that i can put the sensor that came with it???
i really want this to work men, thanks for your time
That makes more sense. The more I thought about it, I realized that water temp gauges aren't like tachs, where you can tie them to a standardized signal.
As for where to add your gauges sensor, there really isn't an existing extra hole that I am aware of. I believe that there are plates that can be installed under the thermostat housing that give you a place to install the sensor. I've seen people install them in other cars by drilling and tapping.
I know that others on here have installed them, So, you might want to start a new thread asking where and how people installed their sensors.
Old 11-13-2009, 08:05 PM   #2
yoxx
yoxx's Avatar
Drives: toyota yaris 2008 hatch
Thumbs up
that makes sense, ill start a new thread
now let me ask you a question, do you think that if i use one of the line that you told me from the pin 96 (pink) or pin 97 (blue) i think i could try that and see, because i reeeeeeally don't want to drill a hole on my car, and now that i think there must be a line that i can tap into because, on the speedometer there is two light for temp, one light up COOL so when you start the car and the other is the red light that have the signal of hot temp, anyway let me know what you think
thank again for the time
yoxx is offline   Reply With Quote
Old 11-13-2009, 08:33 PM   #3
I don't believe that it would work. The single wire sensor is a one wire thermocouple. A two wire device, like what is on the car, is a thermistor. A thermocouple generates voltage relative to change in temperature. A thermistor changes resistance based on temperature. So, the output of the two sensor types is completely different.
As for the lights, they are illuminated by the cluster's microcontroller, based on data from the ECM (who processes the sensor data).
Old 11-13-2009, 08:41 PM   #4
yoxx
yoxx's Avatar
Thumbs up
men that socks, cus i really want it to put this water temp gauge on cus it match my tach and my voltmeter, i guess am gonna have to get some sort of adapter so i can get the sensor in
thank buddy
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
