Old 12-06-2009, 06:32 PM   #1
arunto
arunto's Avatar
Drives: 2008 Yaris LB
which kit did you get? I got the Bi-Xenon kit from microimage and it was plug and play. You might want to check your wiring though. The only thing I noticed is that my high beam indicator light doesn't work.
arunto is offline   Reply With Quote
Old 12-06-2009, 06:59 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
PM CTScott for a fix to the hi-beam indicator not lighting up. I took my car to him and all was fixed in about 10 minutes. Something about the way the HIDs are wired causes it not to light, but the fix is very simple.
MGargano is offline   Reply With Quote
HID Kit High-Beam Cluster Indicator Problem Split Cosmetic Modifications (Exterior/Interior) 21 07-24-2010 05:50 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
HID problem hex_yaris Cosmetic Modifications (Exterior/Interior) 3 01-02-2009 11:35 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
