did your cuts include the bumper (plastic), or only towards the top, taking away metal fender material?
Both. Just in case we end up staying with the 15"s we wanted to make sure we had lots of clearance - had we committed to 13"s I would have installed the flares without touching the fenders. But we cut away enough material to make up for the weight of the fiberglass flares.
thanks, that is helpful. I don't want to cut my fenders for the 13's unless I have to.
#4 | |
Your A6s are a little taller (20.9" for the 255), the rear should be fine, the front could be close under compression. If in doubt, pick up some bone yard fenders to hack up.
I'm probably going to raise it a 1/2" and see where that leads me. I'm also putting in the AOE front sway bar, that should help cut the roll just a little bit more.
AKA Samurai Racer
did you manage to find the problem of the misfire on cylinder 1 ?
It is being addressed wed and thurs.
Heading off to the dyno/tuner.
Then up to Toyota in the AM. Hope we get it all worked out.
We had a combination of issues.... The fuel injectors were to big, and someone used the more is better method of tuning.
We installed new plugs and did a baseline run with the Camcon off, the ECU was just flooding the car. It was pulling max fuel trim, 40%, and it was still super rich. Turned the Camcon on for the next run and it was worse, they were adding fuel. The car did not want to idle, and was fouling the plugs. We can only assume it was tuned for FI, and never re-tuned after they pulled it. Shame, because they left power on the table. Our tuner made a number of adjustments and actually got the AFR really good, picked up some power too. But in the end the ECU was still trying to pull fuel back due to the injectors. Went to Toyota today and they replaced them with a OE set of Yaris injectors. The ones in the car were out of a 2003 Celica. We recalibrate the Camcon to work with the smaller injectors, makes really good power now.
Drives: Absolutely red Liftback Join Date: Oct 2008
New life into an tossed aside icon.....very cool!
Obama Can't Gymkhana! |
good luck!
Video is up. Still waiting for the stoppie footage from our SSC car.
http://www.youtube.com/watch?v=4pkdQSV-x3M
I wonder what really good power is...can you say?
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
I was asking the same thing
I Drive a 129whp Yaris ;) |
Less than your car.
Final number will be printed in the magazine.
Heading up to Willow Springs now.
So looking forward to Saturdays practice and qualifying in the rain. I was able to score some "rains" from a buddy, which is just set of used Toyo R1Rs from his ST Civic. Not great, but unlike with the slicks I should be able to stay on the track. Five cars in H Prod, going to be fun. Sat: 8:00am practice 11:30am qualifying Sun: 8:00am warm-up 10:35am race
SportsCar magazine is the official publication of SCCA -- he probably means that one?
Good luck this weekend, you're light, you'll do us proud out there!
| Hood Stay (lift) Instal | 1NZYaris1 | DIY / Maintenance / Service | 31 | 09-22-2016 07:56 PM |
| The opposite sex can't stay away with ssk | POORSHA | DIY / Maintenance / Service | 20 | 08-19-2009 10:41 AM |
| eTiMaGo Stay safe | Bob_VT | Off-topic / Other Cars / Everything else Discussions | 20 | 12-02-2008 05:31 PM |
| Tuned a DBW Toyota yesterday | Turbo&Auto | Performance Modifications | 17 | 08-17-2007 12:04 AM |
| why am I always here?! wtf...i cant stay away.. | Blenjar | Off-topic / Other Cars / Everything else Discussions | 5 | 02-26-2007 10:51 AM |
