#1 | |
USAF_SrA_E-4
thats easy u dont need someone to tell u how to do that its common sence brother but just to give u a start it starts from all the way back check for 2 bolts I dont remeber if the yaris has them
Well i didnt feel like removing the exterior panel just to check if someone knew already if it came out. If the plastic housing is molded or glued to the metal e brake handle i figured someone might know. I tried to pull on it and twist it so figured it might be. Unless someone knows otherwise.
Pics from when i did ssk and h/boot
as for the plastic hand brake peice itself, i have never tried to take it off |
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| DIY For radios that require attaching a wire to parking brake | Slick | DIY / Maintenance / Service | 0 | 04-16-2009 08:14 PM |
| DIY: Changing Factory Door Handles and Lock Cover | redyaris | DIY / Maintenance / Service | 10 | 05-19-2007 05:55 PM |
