Old 12-18-2009, 12:17 AM   #1
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
thats easy u dont need someone to tell u how to do that its common sence brother but just to give u a start it starts from all the way back check for 2 bolts I dont remeber if the yaris has them
Originally Posted by sw07gt
Old 12-18-2009, 12:37 AM   #2
YarisSedan
Drives: 08 Yaris Sedan
Well i didnt feel like removing the exterior panel just to check if someone knew already if it came out. If the plastic housing is molded or glued to the metal e brake handle i figured someone might know. I tried to pull on it and twist it so figured it might be. Unless someone knows otherwise.
Old 12-18-2009, 05:23 AM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Pics from when i did ssk and h/boot
as for the plastic hand brake peice itself, i have never tried to take it off
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
