Old 12-19-2009, 03:12 PM   #4
djct_watt
Drives: 2010 NCP91 5spd
My HID's had quick connects between the ballast and the bulb. . . I've never seen HID's that had fixed cables to the bulb!!!!! How do you change the bulbs when they (eventually) fry? Are you sure there is no wire harness disconnect? It took a lot of work, but it fit (and I have dual beam kit with a large metal control servo for the high/low shield).
I forced 'em through from the back side. . . that sounds so wrong. . .
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Clazzio Seat Cover DIY Install PETERPOOP DIY / Maintenance / Service 31 09-10-2010 03:30 PM
Question about painting the Engine Cover Blue_dragon_192 Cosmetic Modifications (Exterior/Interior) 11 08-05-2009 12:45 PM
MY RUBBER BAND BALL! AGHHH!!! Sodium Duck Off-topic / Other Cars / Everything else Discussions 47 03-06-2009 01:56 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
