Old 12-23-2009, 11:49 AM   #1
At 5mm, I'd say you've a long way to go yet. In my last service report, the shoes were measuring 3mm with 94,000 kms on the odo. I then went back 2 years and checked a service report. Shoes were 3.5mm with 54,000 on the odo. So in 2 years and 40,000 kms, I wore .5mm off of the shoes.
I will be replacing them in the spring fo 2010.
Old 12-23-2009, 11:50 AM   #2
they make a little cyclic squeak that varies with the wheel rotation speed and is only heard when the car's going fairly slow with the brakes off.
I've never heard that. What contacts the rotor when the brakes are off?
Old 12-23-2009, 01:28 PM   #3
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The little metal insert in the pad. It quits squeaking when braking pressure is applied.The pads (and the insert in them) are always in contact with the rotor.
Old 12-23-2009, 01:03 PM   #4
JBIZZ
Drives: 2007 Liftback white
Another thing to consider is that some aftermarket pads may have better stopping force than the original ones. On a different subject the stock belt is very shitty and should be replaced other than OEM. Mine was dry rotted at 25K miles. Stock tire valve stems should be replaced as well with better ones.
JBIZZ is offline   Reply With Quote
Old 12-23-2009, 02:03 PM   #5
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
sounds like an environmental problem, not a toyota problem
belts and tire valves rotted ?
sounds like the car has been stored near, or was or is exposed to, ozone,
or other chemicals or gasses that rot rubber.
could be where you store your car, where you park it, or how it was stored and shipped before purchase
127.0.0.1 is offline   Reply With Quote
Old 12-23-2009, 02:17 PM   #6
YarisSedan
Drives: 08 Yaris Sedan
Oh one note. Some cars dont have wear sensors. Or actually some brake pads dont have wear sensors. Some OE manufactures dont come with them too. There are quite a few toyota ones too. Which is why its good to have your brakes checked twice a year when you are getting your tires rotated.
Old 12-23-2009, 04:07 PM   #7
Yaris Hilton
Smile
There are even some that give an electronic signal.
Front pad lifespan. o89canucks DIY / Maintenance / Service 47 08-20-2012 05:39 PM
Looking for a nice floor mat heel pad that dosnt break the bank... YarisSedan Cosmetic Modifications (Exterior/Interior) 5 12-14-2009 06:42 PM
Front/Rear Brake Wear Zippo152 DIY / Maintenance / Service 17 06-03-2009 02:12 AM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
hawk performance pad non-availability explained dsc_pat Performance Modifications 6 09-23-2007 11:58 AM
