Old 12-24-2009, 12:34 PM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
awesome shocks...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 12-24-2009, 01:32 PM   #2
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Lafiro , there are several ways to attack your dilema . 1. Get a coilover system that has adjustable height and dampening . Set the height to the height that you have with the TRD's then set the dampening to soft . 2. Change wheel tire combination . The smaller the sidewall number , the more harsh the ride . Larger wheels means you have accomodate by using a lower sidewall number . 3. Get adjustable (dampening) shocks . The TRD springs will work fine .
I have 2 Yari LB's . One ( white , 2007 ) has TRD shocks with Tein springs . The other (blue , 2009 ) has TRD shocks and springs . The white Yaris has 195/55/15 as tires and the blue has 185/60/15 for tires . When I go on a long trip I take the blue , but when I go to the track I take the white . The blue is noticeably softer .
Also keep in mind the C300 is much heavier and has a longer wheelbase which both aid in dampening .
I think if you go with an adjustable shock in conjunction with the TRD springs and use stock tire size you will be fine . If you still want softer just switch the TRD's for the stock springs .
Hope this helps......
Old 12-24-2009, 05:47 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Originally Posted by kngrsll View Post
awesome shocks...
What size are your tires? You don't rub at all on the front IIRC/
Old 12-25-2009, 10:53 AM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
195/55/15 dunlop star specs. when i had the HTS's, DF210's, and rear sway bar, i didnt rub. i just used a dremel on the upper strut holes to help gain some more camber (-2.5* from -1.8) and now i have a slight rub, so ill have to figure that out, but its only when i really jerk the wheel hard and fast.
Old 12-28-2009, 04:20 PM   #5
PHXDEMON
PHXDEMON's Avatar
yeah my tires are a lot bigger than that. I think they are like 215s so I'll probably still rub a little bit
Tokico HP (blues) Shock/Strut driving impressions. largeorangefont Wheels, Tires and Suspension Forum sponsored by The Tire Rack 24 09-09-2010 12:03 AM
Tokico Shocks - Set of 4 WeSellCarParts WeSellCarParts 44 12-25-2008 03:15 AM
Tokico Blues + NF210s Installed bdc87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 11-26-2008 09:39 PM
Tokico Information nemesisz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-25-2007 08:21 AM
Performance shocks Absorbers (amortiguadores de alto desempeņo) carlosh Central and South America 8 08-20-2007 09:21 AM
