Old 12-25-2009, 05:46 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by Yaryaryaris View Post
So i take it know one here knows a damn thing about this topic?
I think what it really is is not too many people are online right now but spending time with their family for the holidays. Try waiting till tomorrow or Monday you should see more replys.
Old 12-25-2009, 06:32 PM   #2
Yaryaryaris
Yaryaryaris's Avatar
Drives: 2007 Yaris HB 5-spd
I figured that. My comment was more toward the "get taller tires" drive-by comment (which I already know and isn't helpful in the slightest)
I'm already finding info on other sights suggesting the sedan has a taller 5th gear than the HB? is this true?
Also, the 5th gear from the Echo is taller (as I suspected) and might be swapped out quite easy.
I'll keep looking around.
Oh, it IS Christmas day. Is that why all the stores are closed? Shows how much I pay attention to such things...:)
I can see for Miles and Miles...
Yaryaryaris is offline   Reply With Quote
Old 12-26-2009, 01:24 AM   #3
YarisSedan
I see a lot of people who auto x get shorter tires and smaller rims to increase their acceleration. I would think the opposite of larger diameter rim and combined with a larger tire you would get slower acceleration but it would make it easier on your engine once you get up to speed. Thus lowering your rpms at highway speeds if thats your only concern.
A heck of a lot cheaper than tearing out your transmission and rebuilding it or swapping in another.
Old 12-26-2009, 06:07 PM   #4
Yaryaryaris
Swapping out the 5th gear in a FW vehicle is often quite easy. I've done it to two other vehicles without even removing the trans. The final drive gear would be trickier.
So far I've read that the echo has a taller 5th gear (by a little) and a slightly taller final drive. The entire trans. doesn't seem to be swappable from what I understand.
Boy do I regret digging this thread back up.
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
gears of war 2 ROCKLAND TOYOTA Off-topic / Other Cars / Everything else Discussions 25 02-16-2009 10:33 PM
Transmission versus Gears caveatipse General Yaris / Vitz Discussion 3 09-23-2007 03:50 PM
Engine Run-on changing 1st/2nd Gears Ferret_san General Yaris / Vitz Discussion 4 09-06-2007 12:21 AM
Gears bulldogs2k Performance Modifications 17 07-26-2006 08:16 PM
