Old 12-28-2009, 02:13 AM   #1
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
http://www.1010tires.com/WheelOffsetCalculator.asp to calculate offset
basically the rim width split in half is 0 offset, higher offset say +45 (stock wheel) compared to a +35 (assuming same width) means the +45 wheel sits in 10mm more. Use the calculator because it gets more difficult to compute when different width wheels are used. One thing i have been told is the yaris is set crooked on the frame, my right rear rubs with weight on bump/pot hole (my tires are shorter too), visibly sits further out than rear left. Im on 12mm spacer, so if i could get a 10mm i should be fine. Either roll the fender or camber shim, or take out the spacer.
Check out my Build thread:
Old 12-28-2009, 04:34 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Mine is the same way Wonder why toyota did that. When I first noticed it I thought my frame was tweaked and my car had been in an unreported accident.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
