Old 12-27-2009, 08:16 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Another "my tires are rubbing thread what can i do about it"....
Okay so my suspension is as follows. TRD springs 10mm spacers and i have konig feathers with 205/55/15s. Not sure about the offset or really what offset means. My best guess is its how offset the rim is from the center of the hub? Which would explain why the same tires on same size rims the stock ones did not rub but soon as i changed the rims its rubbing now. Seems most prominent when going over a huge bump or a pothole on high speeds and also if someone else is in the car.
Looking at a few of my options the obvious one would be to go to a smaller diameter tire like a 50 but that would be a waste of money at this point as my tires are brand new.
I am also thinking of getting tokiko shocks and struts. I am hoping that will cure all my problems. Hopefully someone else who has put on rims and tires on lowered springs but didn't not change their struts can post their before and after results.
Lastly i am thinking of rolling the fenders. Looking at where the tire is hitting the fender i don't think it will help much. The rear tires are hitting a bit as well but i attribute that to the hub spacers i have in already. I am debating about taking out the spare tire to see if that would make any difference with the rear rubbing. My commute is non freeway and i keep a AAA card in my wallet at all times.
What do you guys think, few experts come to mind when i think about asking wheel and tire questions if you could chime in.
Old 12-28-2009, 02:13 AM   #2
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
http://www.1010tires.com/WheelOffsetCalculator.asp to calculate offset
basically the rim width split in half is 0 offset, higher offset say +45 (stock wheel) compared to a +35 (assuming same width) means the +45 wheel sits in 10mm more. Use the calculator because it gets more difficult to compute when different width wheels are used. One thing i have been told is the yaris is set crooked on the frame, my right rear rubs with weight on bump/pot hole (my tires are shorter too), visibly sits further out than rear left. Im on 12mm spacer, so if i could get a 10mm i should be fine. Either roll the fender or camber shim, or take out the spacer.
Check out my Build thread:
Old 12-28-2009, 03:38 AM   #3
YarisSedan
My rubbing only occurs on driver side which makes sense cause thats where im sitting so thats where the weight is. But even with a passanger to balance the weight out it still only occurs on front and back on drivers side. So if i dial in negative camber in the front this should help a little right? I am getting excessive outer wear already from excessive hard cornering so this should balance things out.
Old 12-28-2009, 04:19 AM   #4
ezhacker1
ezhacker1's Avatar
sounds like your car is crooked too. width and offset of your wheels must be close enough to have rub.
Old 12-28-2009, 09:46 AM   #5
Back when the PG spacers were first coming out, people installing the 13mm starting posting about rubs on the left side but not the right. It was becoming apparent that the Yaris hubs are not positioned equally in the rear wheel wells. The left hub sits a few mm more outboard than the right hub.
Old 12-28-2009, 10:55 AM   #6
YarisSedan
Hmm thats really strange.
Old 12-28-2009, 10:56 AM   #7
YarisSedan
Knowing this PG spacers should be made uneven slightly. Like it should come in a 8mm and 10mm pack and 13mm and 11mm to offset this imbalance.
I just went out and looked at my tires the one that has the worse damage from rubbing is the left rear. While the right rear has none at all. Strange....
Old 12-28-2009, 11:21 AM   #8
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
offset! very important..
Old 12-28-2009, 04:18 PM   #9
counterfiend
Drives: 2005 Ford Focus
If your not rubbing, your not low enough :-)
counterfiend is offline   Reply With Quote
Old 12-28-2009, 04:23 PM   #10
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
I'll be able to give you feedback once I get my tokicos from garm in the mail.
Old 12-28-2009, 04:34 PM   #11
PHXDEMON
PHXDEMON's Avatar
Mine is the same way Wonder why toyota did that. When I first noticed it I thought my frame was tweaked and my car had been in an unreported accident.
Old 12-28-2009, 04:52 PM   #12
YarisSedan
Well after some researching I guess im going to roll the fenders. I bought the tool one bay and going to give it a try once it comes in. Maybe post a mini diy. Hopefully there is no cracking in the clear coat. I am just going to roll the upper portion just a bit not the entire fender. Really thats only where the rubbing is anyways. If it works id be willing to roll local members fenders for a small fee maybe 35 dollars. Heck of a lot cheaper than paying a professional bodyshop.
Old 12-28-2009, 05:51 PM   #13
Brentorius
Drives: 07 Mazda MX5 Copper Red
I rolled the fender on my <former> miata. Heat it up well and go slow; you should be fine.
Brent
Former Yaris Owner
Brentorius is offline   Reply With Quote
Old 12-28-2009, 10:12 PM   #14
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Buy 195/50/15 on some 15's....Im using 185/55/15 on my rota slips and stretching them an inch :)... But i rub on stockers with TRD springs when i have 4 people in the car which is bad cause now its going to be dumb with my coilovers on and a 2.5" drop :(
Old 12-28-2009, 10:42 PM   #15
ezhacker1
ezhacker1's Avatar
thats exactly what i think should be done. In my case, my right rear is noticeably sticking out more and rubs.
Old 12-28-2009, 11:57 PM   #16
counterfiend
Rolled the fenders on my fiances yaris and she is WAY lower then you. Still rubbed. Check the part of of the innner fender where the fender bolts to the bumper. That big part that stick out is where she was rubbing. Cut it out, used a selt tapping screw to hold it all together, no more rubs. Well that is until we corrected all camber and now it rubs a little agian. Next we have to pull the fenders.
Old 12-29-2009, 12:05 AM   #17
ezhacker1
ezhacker1's Avatar
^ are you referring to the gooey stuff that im assuming is a type of glue to hold stuff together?
Old 12-29-2009, 03:05 AM   #18
counterfiend
Nope. The actual plastic tab that goes between the 2 to hold them together.
Scraped the glue off so i could roll the fender farther up.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
