Old 12-27-2009, 08:16 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Another "my tires are rubbing thread what can i do about it"....
Okay so my suspension is as follows. TRD springs 10mm spacers and i have konig feathers with 205/55/15s. Not sure about the offset or really what offset means. My best guess is its how offset the rim is from the center of the hub? Which would explain why the same tires on same size rims the stock ones did not rub but soon as i changed the rims its rubbing now. Seems most prominent when going over a huge bump or a pothole on high speeds and also if someone else is in the car.
Looking at a few of my options the obvious one would be to go to a smaller diameter tire like a 50 but that would be a waste of money at this point as my tires are brand new.
I am also thinking of getting tokiko shocks and struts. I am hoping that will cure all my problems. Hopefully someone else who has put on rims and tires on lowered springs but didn't not change their struts can post their before and after results.
Lastly i am thinking of rolling the fenders. Looking at where the tire is hitting the fender i don't think it will help much. The rear tires are hitting a bit as well but i attribute that to the hub spacers i have in already. I am debating about taking out the spare tire to see if that would make any difference with the rear rubbing. My commute is non freeway and i keep a AAA card in my wallet at all times.
What do you guys think, few experts come to mind when i think about asking wheel and tire questions if you could chime in.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
Selling winter tires and low profile floor jack with 2 stands voodoo22 Canada 10 11-16-2009 09:12 PM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 01:23 AM
