| View Poll Results: Should I remeve the NST bushing kit before having the clutch replaced? | |||
| Leave the NST bushing kit in the car during service |
9 | 36.00% |
| Remove the NST bushing kit before bringing the car in |
16 | 64.00% |
| Voters: 25. You may not vote on this poll | |||
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Clutch getting replaced; questions
As you may or may not have read in the "clutch shudder thread," the dealership is putting in an all-new clutch (disc, flywheel, throw-out bearing). I have about 24,000 miles on my car. (Same thing happened to my '05 xB at nearly the same mileage.)
I have the full NST shifter lineup on the car, and I'm a bit worried about the dealership tossing out the NST bushing kit in the engine bay, since it's a non-stock item (I'm afraid they'd junk it and put in new parts not knowing). Do you think I should remove it, or just keep it in there?
Subcompact Culture: The Small car blog |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
I would take it off. Dealers look for anything to get out of warranty work
I would say keep them in there, since they pretty look the same as OEMs. Just let them know and you should be fine (I would be surprised if they refused to work under warranty because of some bushings).
Are you getting an OEM replacement clutch? I got the ACT Stage 1 and it rocks... A bit harder than OEM, but lots of fun to use.
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#4 | |
![]() ![]() I am getting a stock replacement clutch, since they'll foot the bill. My car doesn't need any more than that (I just run a different intake and axleback).
I love momentum.
I would put the stock stuff back in. Don't give them any reason to hassle you if you can avoid it.
TRIM HUNTER
Drives: 2007 BLAZIN BLUE YARIS 3 DR Join Date: May 2006
id leave it in seeing as they probably DON'T know the difference between the two.....
http://rocklandtoyota.com/IFrame.aspx?iFrameID=2388 TOYOTA PARTS AT A DISCOUNT........ |
Well, here's a thought: Will they necessarily need to remove the linkage to replace the clutch? (Might be a dumb question, but I'm not sure, honestly)
FYI, I was looking over the service sheet they gave me yesterday, and it says the car has a warped pressure plate.
![]() Drives: toyotas Join Date: Dec 2009
make sure its on your work order and youll be fine...but make sureee its on there,that is your guarentteeee
i wouldent doubt your pressure plate is warped,they wouldent have wrote something like that down if it wasnt...ask to see for yourself if you doubt them. |
[QUOTE=tk-421;428728]I would say keep them in there, since they pretty look the same as OEMs. Just let them know and you should be fine (I would be surprised if they refused to work under warranty because of some bushings).
QUOTE] wont be an issue at all, and if it is, take it into a more reputable toyota dealership. |
I don't think that assembly comes out to drop the clutch, but I can't remember for sure.
Yeah; I'm thinking if they saw the pressure plate was warped, they probably already took out whatever they needed already. I'll probably just leave it.
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
Clutch change out
I changed the clutch on my wife's corolla. I made a bridge across the shock towers out of 2x4s to support the engine while I dropped the tranny. It was a real bitch of a job. Your lucky your dealer will cover it.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
Only Happy When it Rains
man, i wish i could change a clutch!
Colin Chapman disciple |
#14 |
Well, I'm still debating. Unfortunately, I'm kinda running out of time since I've been working a lot. I also have the K&N intake system on the vehicle; I hope they don't mess that up, either!
I'm just trying to think whether or not they'll even need to disconnect the linkage to change out the clutch ...
#15 |
TRIM HUNTER
kinda depends on tech doing job. each guy has his/her own way of doing things. from what im told they wouldn't have to take apart that linkage if it was done here.....
#16 |
Thanks for checking; I appreciate it!
#17 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
it will have to be removed if they do it properly. to change a clutch the tranny needs to be removed. it is a serious job. i did it once, never again. left wheel assembly needs to go away and if ure good the transmission can be slid over to the left, didn't know that so i ended up putting it right down to the floor, either way, yes that needs to be removed. i doubt they will say anytihng
#18 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Regarding those bushings, do they improve the vague feeling of the shifter? And how much more vibration (buzz) is tranferred back through to the stick with the rubber dampening gone?
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Tags |
| clutch |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Has anyone replaced their clutch | RUBBERDIPSTICK | DIY / Maintenance / Service | 13 | 11-16-2009 05:07 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
