Old 10-30-2009, 12:27 PM   #1
RUBBERDIPSTICK
Drives: Toyota Yaris Base Sedan
Has anyone replaced their clutch
My yaris is getting up there in miles and I'm going to need to replace the clutch pretty soon. I'm a fairly decent back yard mechanic and am thinking about doing the job myself. Has anyone done it? I've downloaded the service manual, and it looks like a pretty extensive job.
RUBBERDIPSTICK is offline   Reply With Quote
Old 10-30-2009, 12:29 PM   #2
hatchbackkid82
Drives: .
i thought someone told me you have to drop the sub frame
Old 10-30-2009, 12:53 PM   #3
RUBBERDIPSTICK
Thats what the manual says...wonder if its really that hard to do
Old 10-30-2009, 12:58 PM   #4
RUBBERDIPSTICK
I just can't stand taking my car to the dealership/shop
Old 10-30-2009, 01:14 PM   #5
hatchbackkid82
Drives: .
You may have to bite the bullet, that's how all the RSX's and SI's are laid out. I think you have to take the whole suspension apart, and disconnect the axles
Old 10-30-2009, 01:33 PM   #6
RUBBERDIPSTICK
Well, I'm pretty sure I can get all of it apart at home, its just getting the subframe/suspension aligned properly that worries me...
Old 10-30-2009, 01:38 PM   #7
hatchbackkid82
Drives: .
Do you know how much the dealership is charging for the labor?
Old 10-30-2009, 08:18 PM   #8
bear4
Drives: 2007 yaris
I am interested in replacing the clutch on my 2001 Echo myself too. Has anyone done the clutch on the Echo? Mine is still good but with 152,000 miles already I expect I may have to do it by 200,000 miles mark... Is there any statistics on how long the clutch lasts on average if mostly highway driving?
bear4 is offline   Reply With Quote
Old 10-30-2009, 08:31 PM   #9
frownonfun
frownonfun's Avatar
i had my dealership put in a flywheel and clutch and i think it was somewhere between $700 - $800. if i remember correctly.
I crush you like tiny clown car, because you are clown, yes?
Old 10-30-2009, 08:38 PM   #10
bear4
Drives: 2007 yaris
This price is not bad for the dealership...
Old 11-02-2009, 05:12 PM   #11
bear4
Drives: 2007 yaris
You don't need to align the subframe, it goes on one way only and suspension alignment can be done by any tire place...
Old 11-16-2009, 12:44 PM   #12
RUBBERDIPSTICK
Bump...has anyone done this?
Old 11-16-2009, 04:41 PM   #13
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
In an Echo - yes, but not in a Yaris, although I don't expect it would be all that much different.
rob323 is offline   Reply With Quote
Old 11-16-2009, 05:07 PM   #14
bronsin
bronsin's Avatar
It all depends on the driver and his/her technique. The friction disk could be done in 20,000 miles or 200,000 miles. I had a 74 Beetle with 250,000 miles on the friction disk. And it was still good. I put 100 highway miles a day on it and treated it like glass. If you wear the lining into the rivets there goes your pressure plate and flywheel meaning another $$$$. After 152K it could be there. Its strictly your call.
Clutch shudder when setting off in 1st gear BuildCode DIY / Maintenance / Service 87 06-17-2015 07:14 AM
Help Me Find The Right Clutch RacerFreakXXX Performance Modifications 18 10-20-2010 05:20 PM
Restarting car after popping the clutch... PaidTimeOff General Yaris / Vitz Discussion 21 02-26-2009 01:40 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
c one motorsport clutch line(pics) badhabitz Performance Modifications 6 07-31-2006 10:08 AM
