Old 01-14-2010, 11:46 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
In theory, the tire with the larger diameter should give slightly better gas mileage. But, as Tamago points out, you need to be sure to correct your MPG calculations because the change in tire diameter is going to make the odometer inaccurate.
Old 01-14-2010, 08:12 PM   #2
karl lee
MY baby VIOS
karl lee's Avatar
Drives: Yaris Sedan
My question is only base on the height of tire sidewall. Let's assume the odometer meter is correct.
I heard somewhere that shorter sidewall(lower profile) will have a better rolling resistance compare to taller. And also tire is slightly lighter. Therefore, should be better mileage for shorter sidewall tire.
Please share your view.
Thanks.
karl lee is offline   Reply With Quote
Old 01-17-2010, 10:13 AM   #3
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
if it's mostly in town driving, i'd think a larger diameter might make matters worse.
Old 01-19-2010, 06:49 PM   #4
SilverGlow
True, but at some point the MPG will actually go down over a smaller tire because as the size goes up, torque goes down.
In general, big tires do better for highway driving, and smaller for city driving because the smaller driving tires have more torque (pulling power) then larger tires....however for mostly highway driving (little stop and go) a bigger tire will provide better MPG, but again, only up to a certain size, then as the tire gets bigger MPG actually gets worse.
SilverGlow is offline   Reply With Quote
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
Yaris Tire size and Fuel Economy 77W Fuel Economy Forum 8 12-17-2009 05:59 PM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
