![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
LED Door Sills
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Which model is the coupe? The hatchback or the sedan?
#3 | |
USAF_SrA_E-4
LB
so that wont fit the 2010 LB?
As far as I know, these do fit the LB (the 5-door one at least):
http://shop.microimageonline.com/pro...4&categoryId=5 |
#6 | |
![]() ![]() ![]() Drives: '07 Yaris Sedan/'03 Protege Join Date: Oct 2008
Yes, they fit both the 5-door and sedan, not the 3-door.
So there are four pieces right? One for each door?
That's the way it seems. I wonder what it would look like if you stuck the two front ones in a 3 door lol.
![]() ![]() Drives: 2010 Yaris 3dr liftback Join Date: Dec 2009
I am sure it would work I am about to try it on my LB.
Is there any way to set the color and leave it on one color? I'd want it white all the time.
PM Garm, he's got them on his site.
#13 | |
you could buy replacements. Yeah, Garm has them, they are the same OEM accessories I used to sell. |
Im sure you can source the bulb and replace them, just have to get a set and look for the bulbs.
Yea these are the exact same ones I bought from you kargoboy when you had them. When it finally gets warmer out I'm gonna attempt to connect them to my dome light. The only issue I have(and it could be from a wrong installation), but they rub against the bottom of the door, especially on the rear doors, which are harder to close now. Not sure if anyone else has run into this who has them, but wouldnt mind a suggestion.
keckbot
Drives: 2007 Blazin' Blue Liftback Join Date: Aug 2011
Bought a set of these off of ebay that are blue led to match my blazing blue yaris. Just got done hooking them up using the DIY on this site. They work perfectly...go out when the dome light turns off when the doors are closed. Although I have to admit, after I had installed one, I was glad I had waited to install the other, because I wasn't sure if they were really turning off when the door is closed and well... when the door is closed you can't see them of course :P so it did make it interesting for a minute. Well worth the $50 investment.
pics or it didnt happen
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| Door Handle LED DIY with pics | window_lee | DIY / Maintenance / Service | 93 | 05-31-2012 11:58 PM |
| DIY LED Strip under the door panel | charleschia1986 | DIY / Maintenance / Service | 19 | 11-05-2011 07:49 PM |
| FS: JDM Modellist II Front bumper & JDM LED tails | DKN-YARIS | Items for Sale by private party | 7 | 11-09-2008 01:10 AM |
