Old 11-24-2009, 06:56 AM   #55
Originally Posted by charleschia1986 View Post
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right?
I already tested the pink wire by multimeter and it will only give 12v when the door is closed.
So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open...
Thanks...
Use the pink as ground and the blue as your +12V.
Old 11-24-2009, 11:55 AM   #56
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
thanks a lot...
i tried and it WORKS.....
thank scott
charleschia1986 is offline   Reply With Quote
Old 12-05-2009, 01:33 PM   #57
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
another useful tidbit for those wishing to wire in LED mirror covers, you can get the signals from each side here. This is for the big relay/junction box in the driver's footwell area.
This way you don't have to go into your engine bay to wire them up
Thankyou ThankYou THANKYOU!!!
zuberio is offline   Reply With Quote
Old 12-06-2009, 02:45 AM   #58
charleschia1986
thanks CTscott for ya Helpsssss,
here is the link of my Final product.
u may have a look.
http://www.yarisworld.com/forums/showthread.php?t=24210
Old 12-22-2009, 10:23 PM   #59
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hi all. Is there a place I can tap into the engine bay for turn signals besides the wires that lead to the signal lamps?
Old 12-22-2009, 11:08 PM   #60
You can tap into the turn signal wires in the under hood fuse panel. On connector B13 (left connector in this picture), the light green and dark green wires in the upper row (next to the two red wires for my fog lights) are the turn signals. Light green is left, dark green is right.
Old 01-21-2010, 01:35 AM   #61
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
One more question, where can I tap in for the parking lights - the lights that go on just before I turn on the headlights?
Old 01-21-2010, 11:32 PM   #62
The White wire next to the blue and orange on the headlight stalk connector. You ground the wire to make the lights come on.
Old 01-22-2010, 01:50 AM   #63
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Sorry, should've made my question a bit clearer. I'm looking to see if there is one in the fuse box like the one pictured above.
Old 01-22-2010, 06:22 AM   #64
In the fuse panel, it is pin 3 on Connector B13, which is the green wire next to the two red wires in my picture above. If you don't have fogs installed, the place where the two reds are in my picture will be empty on yours.
Old 06-09-2010, 10:47 AM   #65
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
jonimac is offline   Reply With Quote
Old 06-09-2010, 11:02 AM   #66
If you tap the pink and blue, the LEDs will behave the same as them dome lights, provided that you leave the dome light switch in the "Door" position. If you manually switch the dome to "On", with the doors closed, the LEDs won't light up with the dome.
Old 06-09-2010, 04:56 PM   #67
jonimac
jonimac's Avatar
Thanks CTScott... got the idea!
Old 09-21-2010, 08:22 PM   #68
Originally Posted by geniusmiki View Post
hi can someone please tell me what are these cables found under the hand brake?
it's an european model.
thanks
http://img337.imageshack.us/g/19072009030.jpg/
The black one is for the Door lock receiver. Does your Yaris have a manual or automatic transmission. If it's a manual, then the other two are for the A/T shift illumination and for the shift lock control ECU.
Old 09-22-2010, 10:54 AM   #69
sleey0
Drives: 2008 Yaris LB
I just want to take a minute to say a big, fat THANK YOU to ctscott for his help on these boards.
I have used a lot of your info and I believe you deserve at least this much appreciation!
Thanks, brother!
sleey0 is offline   Reply With Quote
Old 10-21-2010, 10:23 PM   #70
nmd55
Drives: Yaris Liftback
it tried tapping the light blue wire at the headlight switch, but now my headlight wont turn off and the lights on my power window switches are on all the time?
did i just do a bad job tapping this? or can i not tap the light blue wire for my power window switches?
thanks,
nick
nmd55 is offline   Reply With Quote
Old 10-21-2010, 10:28 PM   #71
Tried tapping that wire for what purpose?
Old 10-22-2010, 11:27 AM   #72
nmd55
the power window switches i got light up at night when the headlights are on
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
