Old 12-22-2006, 11:31 AM   #1
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
Originally Posted by El Jefe View Post
the problem the original poster is having is the a/c compressor kicking on and off, it seems like the computer is over/under compensating for the load change. i've noticed this on mine
the only way to fix this will be a reflash of the ecu to smooth the change out. toyota has no released this as yet and i highly doubt they will. it may be annoying but it causes no ill effect to the car as long as it's not stalling out or anything like that.
But I live in San Francisco, I've never even used the a/c. I'm just satisfied knowing that this is a problem with more than just my car. I do agree with you though, I doubt Toyota will ever do a recall to fix the problem.
Galavoxx is offline   Reply With Quote
Old 12-22-2006, 04:59 PM   #2
El Jefe
Drives: 07 yaris s sedan
how often do you have your car in either of the defrost settings? that also turns the a/c compressor on even tho the little light does not come on.
try it out and let me know, test it with the a/c on or in defrost mode, and then with everything totally off.
El Jefe is offline   Reply With Quote
WR Secret Weapon Intake Dyno Tested.. WRLEO Performance Modifications 70 05-17-2007 03:00 PM
