Old 01-27-2010, 09:26 PM   #1
Originally Posted by frankencar View Post
So this may be a silly question but... this works on an AT liftback as well? Just ignore the parts that say "MT only?"
Also, I'm a bit confused on the part where you connect to the ECU. Is there a specific crimp/connector, some other method to plug into the ECU?
Correct on the AT - Works the same and ignore the clutch switch part.
For the ECM connection (on 06-08 Yaris), you need to actually add a pin to the smaller of the two connectors on the ECM. I highly recommend using the actual Toyota "repair terminal", which is the pin with its waterproof sleeve and a piece of wire pre-connected to it. (Part number: 82998-24250)
Old 01-28-2010, 05:20 PM   #2
upgradedyaris
Drives: Yaris & Supra
You forgot to add your module for the led. ;) A plus!
Duane
upgradedyaris is offline   Reply With Quote
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
