Old 01-29-2010, 08:25 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Reviding the pictures I could answer my own questions....
The engine can't be used with forced induction because of the ""auxiliary intake induction system" since boosted air will be forced out instead. Saying this...... so why using lower compression pistons on an N\A engine cause you will only loose power that way. If you want to change pistons it would be better to plan for slightly higher compression ones keeping in mind good valve clearance.
Also ... what about fuel injectors? Are they still stock?
Parmas is offline   Reply With Quote
Old 01-29-2010, 09:47 PM   #2
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
yes the engine can still use forced induction, because the there are 1 way valves in the auxiliary intake induction system ( the forced air can not escape through the valves ). My tuner do many forced induction cars with the auxiliary induction system.
i don't think the piston is that low compression, i will re-check again.
the fuel injectors are still stock but i clean it periodically.
sujonol78 is offline   Reply With Quote
Old 01-29-2010, 10:24 PM   #3
sujonol78
Drives: 1nz-fe / MT
the dyno was on the engine.
Old 01-29-2010, 10:28 PM   #4
sujonol78
Drives: 1nz-fe / MT
we can not judge a piston by just its' appearance, there are other influencing factors too. for the piston that i use, it is not as low as it seems, but also not as high as you might think. it depends on the other supporting factors and tuning. the end results for my piston is slightly touching the high compression area.
Old 01-29-2010, 10:53 PM   #5
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
So it's like you gave yourself a whole bunch of vacuum leaks with all the unmetered air from the butt dyno tuned "auxiliary air intake" system, although I really can't see much air actually getting through all those tiny little tubes, filters, and valves anyway.
Originally Posted by sujonol78 View Post
132HP was on Apexi, TRD clutch ( original ), auxiliary intake, JFC filter, and custom muffler only.
You're claiming you got about 23hp from an AFC, air filter, and a muffler?
Old 01-29-2010, 10:59 PM   #6
sujonol78
Drives: 1nz-fe / MT
Originally Posted by TOUGEghost View Post
So it's like you gave yourself a whole bunch of vacuum leaks with all the unmetered air from the butt dyno tuned "auxiliary air intake" system. Although I really can't see much air actually getting through all those tiny little tubes, filters, and valves anyway.
don't worry, a lot of people don't believe it either, but once you have tried it, then it is a completely different story
Old 02-01-2010, 01:18 AM   #7
sujonol78
Drives: 1nz-fe / MT
yes
Old 02-01-2010, 01:53 AM   #8
sujonol78
Drives: 1nz-fe / MT
i respect all the things you've done to increase the performance of your engine, i even learn something good from this forum. i never said it is a mistake, i never said that the things i did with my engine is the only "right" way. please understand the difference between tuning and modifying ( or even "replacing" ). yes, the stock engine holds a great potential without having to modify or replacing it with performance parts, so that's why we ( my tuner and i ) are exploring the hidden potentials, and i have shown you the results without any exaggerations or lies.
the same dispute also occurs in my country, so no harm done.
now you know there are "unconventional" ways to explore the hidden potentials with, if i may say, a more efficient way.
PS: I'm not from Puerto Rico, I haven't done anything to the stock ECU, and the PCV valves really works, and I don't care for popularity.
Anybody in the Phoenix Area want to have a get together? kustom play Southwest 12 09-13-2009 11:52 PM
FS: Micro Image 1NZ Engine Cover (Black) Treyz Items for Sale by private party 10 06-13-2009 01:04 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
Ask The Phoenix The Phoenix Off-topic / Other Cars / Everything else Discussions 25 09-06-2007 09:24 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
