Old 03-21-2015, 09:13 PM   #1
Originally Posted by Gitaniio View Post
Unfortunately there was no voltage there. Is there any other way to install a CC in my yaris? Thank you for your time.
Your options would be to either switch the ECM to a US spec one or use an aftermarket cruise control system.
Old 09-25-2019, 12:32 PM   #2
rebelluck
Drives: 2015 Toyota Yaris L
Does my american 2015 Yaris L have prewired cruise control? Hoping for just a plug and play here.
rebelluck is offline   Reply With Quote
Old 09-26-2019, 01:47 AM   #3
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It should just be a matter of mounting and plugging in the control stalk.
Have a look at http://yarisworld.com/forums/showthread.php?t=37205
The 2015 should only be a facelift from 2012.
Old 08-08-2015, 08:39 AM   #4
CB900F2
Drives: 08 Sedan
Hi all..
My cruse control stopped working last night on the way home, and so I removed the switch, and took it apart, and low and behold, the ON/OFF pushbutton wires, one broke off its solder point.
Stripped the wire a bit, and re soldered, and bingo! back in business..
regards
Old 08-08-2015, 09:01 PM   #5
Originally Posted by CB900F2 View Post
Hi all..
regards
Interesting. I haven't heard of that happening yet, but there is always a first. Thanks for sharing, as I am sure you will not be the last.
Old 08-16-2015, 11:31 AM   #6
hayden
Drives: asd
Any idea how difficult or whether this would be possible on the 2015 model? I did it once before on the 2007 model but I have no idea how much different the 2015 model might be. Would the connectors even be the same?
hayden is offline   Reply With Quote
Old 08-16-2015, 09:32 PM   #7
The 2015 is the same as far as the stalk goes and does not require any additional wiring, like your 2007 did. If it is a MT, you will need a clutch switch as well.
Old 08-16-2015, 04:10 PM   #8
Eduardo_mty
Hayden i did it on my 2015, is Quick and easy,
Eduardo_mty is offline   Reply With Quote
Old 08-16-2015, 06:42 PM   #9
hayden
Drives: asd
Great, thank you. Did you use the same instructions as the 2012 model?
Old 08-16-2015, 07:01 PM   #10
Eduardo_mty
Yes... If i remember well, i open a thread
Old 08-16-2015, 07:05 PM   #11
Eduardo_mty
Cruise control, yaris 2015, 5 Speed, is the name of my thread
Old 08-20-2015, 10:13 AM   #12
hayden
Drives: asd
Awesome, thank you!
Old 03-11-2016, 09:24 PM   #13
bambam28
Drives: Yaris Hatchback 2012 SE
Hello guys quick question, I have looked through the diagrams and I cant seem to find the cable that attached to the Cruise Control Clutch Switch (Required for all Manual Transmission Yaris): 88280-14030. Can anybody help me out with the part number of that cable?
thank you
bambam28 is offline   Reply With Quote
Old 03-11-2016, 10:50 PM   #14
thank you
No need - The cable is part of the harness, so it is already present on your car. Look up above the clutch arm and you will see the white connector taped to the harness above it.
Old 12-23-2016, 09:25 AM   #15
colindoling
Drives: 2008 Yaris Sedan
I have a Canadian 2008 sedan I bought a kit online years back it only works for the first 5 to 10 minutes of driving the Yaris and then stops working like I can get on to the highway set it at 100 and it will hold there till I hit the brakes.. but the switch stops working like no exceleration or deceleration you can't even turn it off or cancel with the stock so I'm lost on why it's doing this anyone have some insight?
colindoling is offline   Reply With Quote
Old 12-23-2016, 10:12 PM   #16
What type of kit did you buy?
Old 01-12-2017, 08:54 PM   #17
colindoling
i bought a rostra kit
Old 01-05-2017, 08:28 PM   #18
max924
Drives: 2010 Yaris Sedan
Hi Scott, I have a 2010 Yaris sedan with manual trans, pwr windows/locks and ac. Can you send me the list of parts required for the cruise control and pricing?
I tried sending a pm and it did not seem to work so just posting here...
Thanks!
Max
max924 is offline   Reply With Quote
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
