Old 08-08-2015, 08:39 AM   #1
CB900F2
Drives: 08 Sedan
Hi all..
My cruse control stopped working last night on the way home, and so I removed the switch, and took it apart, and low and behold, the ON/OFF pushbutton wires, one broke off its solder point.
Stripped the wire a bit, and re soldered, and bingo! back in business..
regards
Old 08-08-2015, 09:01 PM   #2
Originally Posted by CB900F2 View Post
Hi all..
regards
Interesting. I haven't heard of that happening yet, but there is always a first. Thanks for sharing, as I am sure you will not be the last.
Old 08-16-2015, 11:31 AM   #3
hayden
Drives: asd
Any idea how difficult or whether this would be possible on the 2015 model? I did it once before on the 2007 model but I have no idea how much different the 2015 model might be. Would the connectors even be the same?
hayden is offline   Reply With Quote
Old 08-16-2015, 09:32 PM   #4
The 2015 is the same as far as the stalk goes and does not require any additional wiring, like your 2007 did. If it is a MT, you will need a clutch switch as well.
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
