Old 08-08-2015, 10:01 PM   #1
Originally Posted by CB900F2 View Post
Hi all..
My cruse control stopped working last night on the way home, and so I removed the switch, and took it apart, and low and behold, the ON/OFF pushbutton wires, one broke off its solder point.
Stripped the wire a bit, and re soldered, and bingo! back in business..
regards
Interesting. I haven't heard of that happening yet, but there is always a first. Thanks for sharing, as I am sure you will not be the last.
Old 08-16-2015, 12:31 PM   #2
hayden
Drives: asd
Any idea how difficult or whether this would be possible on the 2015 model? I did it once before on the 2007 model but I have no idea how much different the 2015 model might be. Would the connectors even be the same?
hayden is offline   Reply With Quote
Old 08-16-2015, 10:32 PM   #3
The 2015 is the same as far as the stalk goes and does not require any additional wiring, like your 2007 did. If it is a MT, you will need a clutch switch as well.
Old 08-16-2015, 05:10 PM   #4
Eduardo_mty
Hayden i did it on my 2015, is Quick and easy,
Eduardo_mty is offline   Reply With Quote
Old 08-16-2015, 07:42 PM   #5
hayden
Drives: asd
Great, thank you. Did you use the same instructions as the 2012 model?
Old 08-16-2015, 08:01 PM   #6
Eduardo_mty
Yes... If i remember well, i open a thread
Old 08-16-2015, 08:05 PM   #7
Eduardo_mty
Cruise control, yaris 2015, 5 Speed, is the name of my thread
Old 08-20-2015, 11:13 AM   #8
hayden
Drives: asd
Awesome, thank you!
Old 03-11-2016, 10:24 PM   #9
bambam28
Drives: Yaris Hatchback 2012 SE
Hello guys quick question, I have looked through the diagrams and I cant seem to find the cable that attached to the Cruise Control Clutch Switch (Required for all Manual Transmission Yaris): 88280-14030. Can anybody help me out with the part number of that cable?
thank you
bambam28 is offline   Reply With Quote
Old 03-11-2016, 11:50 PM   #10
thank you
No need - The cable is part of the harness, so it is already present on your car. Look up above the clutch arm and you will see the white connector taped to the harness above it.
Old 04-07-2016, 06:25 PM   #11
msgm
Newbie
Drives: corolla
i have a Toyota corolla altis 2015 1.6*
Market*General###Year 06/2014###Make TOYOTA###Model*ALTIS / COROLLA###Frame*ZRE171###
Model code
ZRE171L-GEPNKV
ECU part *number : 89661-0ZE60
I tried to add cruise control switch to non pre-wired Toyota corolla 2015 . But i did a mistake in wiring install , i*got an error on the instrument panel on the screen " error cruise control " with a warning sound !. So i disconnected it , then when i tried again i got nothing even that error doesn't appears again and its not working. So i decided to check switch , wiring , ECU according to the diagram provided from Toyota repair manual repair manual .*
The switch is working good due to multi-meter readings .*
I found later the problem is in the ECU , the pin number 40 in ECU has no volt or ampere . Even the continuity check is 0 , other pins working good reading 11 volt*, So*There is an problem in the ECU*
briefly:*
i tried to check the pin number 40 in ECU and it gives 0 VOLT and 0 AMPERE* and the continuity test is failed that's means the circuit in ECU is disconnected . Can any one help , any advice ?
switch test video https://www.youtube.com/watch?v=QiGhFoB0ZLk
ECU test video "pin 40" https://www.youtube.com/watch?v=tX7JBtD-9i4
msgm is offline   Reply With Quote
Old 04-24-2016, 07:59 PM   #12
LeBnomiS
Drives: 2011 Yaris 3DHB
Hi CTScott, thanks for all the help you are providing.
I have a 2011 liftback MT, no power. According to your guide, there is no need to add wiring from the ECM to steering column for all liftbacks 2009-2011.
Someone asked earlier in the thread if the cruise would work for this particular model and you answered he needed to add the connector D3 pins and run wire to the ECM.
I am confused. Will I need to run the wire or will it be plug and play ?
Thanks again for you time !
LeBnomiS is offline   Reply With Quote
Old 04-24-2016, 09:49 PM   #13
My guide is correct for your car. The other person did not have the same...
Old 05-28-2017, 11:44 AM   #14
geeoye
Drives: 2011 Yaris Hatchback 5Dr
CTScott,
I have a 2011 Yaris Hatchback 5Dr which I bought a week ago. It has a 43K miles on it. It has all the power windows and power doors. I was wondering what do I need to install the Cruise control in it.
Much appreciate it.
Geeoye
geeoye is offline   Reply With Quote
Old 05-29-2017, 11:01 PM   #15
Ranger SVO
Drives: 2010 Yaris
Originally Posted by geeoye View Post
CTScott,
Much appreciate it.
Geeoye
You may only need the handle
http://www.yarisworld.com/forums/showthread.php?t=25361
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 06-01-2017, 12:01 PM   #16
geeoye
Originally Posted by Ranger SVO View Post
Thanks for the info. Where did you buy the CC handle from. I tried searching for 84632-34011 on Ebay and I get variety of parts. Some are compatible with my 2011 Yaris and some are not. I'd prefer to buy an OEM part.
Old 12-23-2016, 10:25 AM   #17
colindoling
Drives: 2008 Yaris Sedan
I have a Canadian 2008 sedan I bought a kit online years back it only works for the first 5 to 10 minutes of driving the Yaris and then stops working like I can get on to the highway set it at 100 and it will hold there till I hit the brakes.. but the switch stops working like no exceleration or deceleration you can't even turn it off or cancel with the stock so I'm lost on why it's doing this anyone have some insight?
colindoling is offline   Reply With Quote
Old 12-23-2016, 11:12 PM   #18
What type of kit did you buy?
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
