Old 02-01-2010, 08:58 PM   #1
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
no, forged rods are the same exact specifications as stock ones, in terms of shape and function. I have forged rods with stock camshafts and stock crankshaft.
Changing the rods simply does not change the power output of the motor.
i understand, but my idea of replacing the con-rod is with "lighter" con-rod material, if it is lighter, i think it will affect the lower power band. that's why when i change to the lighter rod, i will also change the camshafts. what do you think?
sujonol78 is offline   Reply With Quote
Old 02-01-2010, 09:02 PM   #2
sujonol78
Drives: 1nz-fe / MT
it seems that we have a misunderstanding about the dyno method. as i mentioned before, it was on engine. for the next step i will use on the wheel
Old 02-02-2010, 04:34 PM   #3
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Reducing conrod weight will have only a very marginal effect on the reciprocating mass. In other words, I severely doubt if you could tell the difference while driving it.
rob323 is offline   Reply With Quote
Old 02-02-2010, 10:18 PM   #4
sujonol78
Drives: 1nz-fe / MT
thanks for the info, i will keep it in mind for the next step.
Anybody in the Phoenix Area want to have a get together? kustom play Southwest 12 09-13-2009 11:52 PM
FS: Micro Image 1NZ Engine Cover (Black) Treyz Items for Sale by private party 10 06-13-2009 01:04 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
Ask The Phoenix The Phoenix Off-topic / Other Cars / Everything else Discussions 25 09-06-2007 09:24 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
