Old 02-11-2010, 01:39 PM   #1
YarisOwnersDad
Is now a Corolla S Owner
Drives: 2010 Corolla S
Originally Posted by 127.0.0.1 View Post
does it work consistently with the inside switches ?
this is the second button press where the problem occurs ?
or is it programmed to open all on one press ?
the computer can be reprogrammed on the unlock sequence from a keyfob,
maybe it needs to be reprogrammed.
It sometimes doesn't respond to either the key fob or to the lock/unlock button on the driver's door.
Thanks to all for your replies.
Tom
YarisOwnersDad is offline   Reply With Quote
Old 02-11-2010, 02:20 PM   #2
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Tom
the power door ecu is the issue.
maybe needs a hit with a hammer (so to speak)
127.0.0.1 is offline   Reply With Quote
Old 02-11-2010, 02:34 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Hitting things with hammers from my experience usually breaks them than more than fixes them.
Old 02-11-2010, 06:27 PM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
but we still don't know for sure if its just one door or all of them if it was the ecu it would be all doors wouldn't it? it sounds more like the actuator mechanism not the ecu
RELAY.... actuators are not designed for a push function and a pull function. They only know "move"... multiple relays are used to get the whole push/pull function. When one relay is on, the other is off, each time a relay switches to on, the actuator moves... do a google search for relay wiring for door locks and you'll find a diagram of what i'm talking about.
the actuator could be bad... but I doubt it.
kit to install power locks? songa DIY / Maintenance / Service 21 02-12-2015 06:31 AM
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Question about Yaris power locks. OtownYaris General Yaris / Vitz Discussion 3 05-14-2007 09:48 PM
power locks and alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 1 12-01-2006 12:17 AM
