Old 02-17-2010, 02:03 PM   #1
*MAD DOG*
*MAD DOG*'s Avatar
Unhappy
should have bought tires that match your oem sizing...thats not the wheels' fault
Both 15" and 14" are oem if you bothered to read my post.
Old 02-17-2010, 02:23 PM   #2
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Yes, but you are not running correct rubber, meaning the OD is smaller. Yarii do come with both 14 and 15 wheels oem, but they run similar OD tires to match the speedo calibration.
Old 02-17-2010, 03:16 PM   #3
i did bother, but if you knew to size your 14" tires to match your 185-60-15 tire size, you wouldnt be 3.5% off in YOUR oem rotating diameter running 175-65-14's. its simple math to figure out they arent the same diameter. since 185-60-14 =~ 175-65-14, you're actually 1/2" LESS rubber on your sidewall, and thus 1" shorter overall.
its a post i've made before since my car came with 14's and i mentioned that the speedo seems off according to gps (again confirmed this weekend going up north)
i think all yaris speedo's are set to 185-60-15 sizing, not 175-65-14.
WTB: 4 15" alloy rims _Bravo_ Willing to Buy by private party 2 02-19-2010 06:39 PM
15" Chopper Rims for sale 33lam Australia 12 10-11-2009 01:01 AM
Does Toyota reset the speedo for the Yaris that have 14" and 15" rims? detroiter General Yaris / Vitz Discussion 19 05-17-2009 08:46 AM
Can I use stock tires on these 15" rims? songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 02-18-2009 07:11 AM
FS: OEM 15" Scion Rims & Tires....Brand New crabbadam Canada 5 11-27-2008 06:14 PM
